Rear wiper plug for 92-95 Civic HB
Hello, well I removed my wiper and now have a hole in my rear window and my trunk doesn't stay closed well because the hatch latch is not mounted properly. So I went to Honda to get the #13 plug from the only store but Honda dealer said that they don't make this plug anymore and they can't get it from anywhere. So now I would like to know if the plug #13 is the one I actually need or if there is something else out there that will fix my problem with latch mount.
+ I did some research and found the following but I am not sure if these serial numbers are for civic...
Honda part #
Plug 90301-SR3-000
Bolt 90156-SH3-000
PS: Please help me
Honda part #
Plug 90301-SR3-000
Bolt 90156-SH3-000
PS: Please help me
question why would you take out the rear wiper. Ever driven a hatch back on dirty wet roads with out a rear wiper you cant see out the back window. I wouldn't ever consider take mine out unless you are building a comp track car
put the wiper back on your are not saving very much weight by taking it off (i assume thats why you took it off) unless you drive an all out drag car you will see no benift of not having it. in that case you would probably just get lexan windows
I just don't like the way it looks so that is the reason I am getting rid of it.
And if it does suck a lot without the wiper I'll just pop it back in, it only takes like 10 min to do
i took my wiper out because it get caught my the duckbill and dont go no where.
if you take out the whole wiper assembly you take out the a hatch that locks teh window. got pics of the part that you replace it with to use the plug?
I did take out the whole wiper assembly and now only have the plastic box and the metal bracket inside of it all holding up by a plug that's next to the wiper hole. Now I am looking for some kind of plug that would plug and hold the whole assembly...
dVeLoPe
Sep 4, 2004 05:46 PM
