make my d15b faster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALOWKS »</TD></TR><TR><TD CLASS="quote">what parts could i get from other civic that will give the motor more *****...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALOWKS »</TD></TR><TR><TD CLASS="quote">i was thinking a turbo kit should do the job.... </TD></TR></TABLE>
You don't get turbo kits from Civics. If you're "thinking turbo kit should do the job," I suggest going to the forced induction forum and reading until you have sufficient information to make this decision for yourself. Your engine is a shitty place to start. If you have the money to turbocharge it, you should swap it for a D16Z6 or B18B first and then turbocharge that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALOWKS »</TD></TR><TR><TD CLASS="quote">what car has the z6..
Okay,
1.) could you stop putting "........" at the end of all your questions? The proper punctuation is that squiggly mark with the dot below it. It looks like this > ? <
2.) the D16Z6 comes from a Civic Si 92 - 95 or a Civic EX 92 - 95. If you don't know these basic things, you need to do a lot more research before you think about screwing around with your engine.
Okay,
Start reading
http://www.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/turbo3.htm
http://www.howstuffworks.com/engine.htm
http://auto.howstuffworks.com/engine1.htm
http://auto.howstuffworks.com/engine7.htm
http://auto.howstuffworks.com/question395.htm
http://auto.howstuffworks.com/question122.htm
I was thinking of building the motor befor i buy a turbo.... but the money i was going to spend on the turbo i rather get a vetec head for my b20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALOWKS »</TD></TR><TR><TD CLASS="quote">I was thinking of building the motor befor i buy a turbo.... but the money i was going to spend on the turbo i rather get a vetec head for my b20
No on both accounts. You can't pass BAR ref with a B20 or CRVtec, and even if you had an LS-Vtec you still couldn't pass. My adivce would be to ditch the B20 (sell it) and pick up a B18b1 since you have hopes of going turbo. And make sure the turbo kit is CARB certified.
</TD></TR></TABLE>No on both accounts. You can't pass BAR ref with a B20 or CRVtec, and even if you had an LS-Vtec you still couldn't pass. My adivce would be to ditch the B20 (sell it) and pick up a B18b1 since you have hopes of going turbo. And make sure the turbo kit is CARB certified.
