85 accord axle replacement problem!!!
Old Sep 4, 2007 | 08:49 AM
etregoning's Avatar
Default 85 accord axle replacement problem!!!
Hi. i have a 1985 4dr/4cyl/carb. honda accord. i got the axles rebuilt and i got the drivers side axle in with no problems at all. but with the passenger side, i cant get the ball joint on the lower arm to go back into the hub! anyone know what could be the problem?
Old Sep 5, 2007 | 10:56 AM
etregoning's Avatar
Default Re: 85 accord axle replacement problem!!! (etregoning)
bump....
? noone knows?
Old Sep 5, 2007 | 02:12 PM
Honda-Master's Avatar
get a big screwdriver and open up the slit on the hub a bit, then make sure that the ball joint is properly aligned when it goes in ..you might have to wiggle it a bit
should be a piece of cake
Old Sep 5, 2007 | 03:49 PM
etregoning's Avatar
Default Re: 85 accord axle replacement problem!!! (Honda-Master)
the drivers side was a peice of cake. but the passenger side is giving me trouble. it seems that the ball-joint is off a bit. its not completely at a 90 degree angle when i try to line it up
Old Sep 7, 2007 | 09:37 AM
etregoning's Avatar
bump----
i was told if the engine mounts were off a bit that could be causing the problem.
i was told either jacking one side of the engine up or getting a BIG pry bar and trying to scoot the engine over a bit might work.
doesnt sound very feasible to me though so im still taking ideas. id like to get my car off the jackstands and back on the road >_>
Old Sep 7, 2007 | 01:24 PM
mounts have nothing to do with it........
put the knuckle opening on top of the ball joint, grab the knuckle and move it around till it will line up properly , it will drop into place,, you might have to hit the lower control arm a bit to go into the knuckle but if you spraed the slit on the knuckle like i suggested it will fall right in
Old Sep 7, 2007 | 08:27 PM
etregoning's Avatar
what im trying to tell u is that it wont line up right
jonesEK
Apr 13, 2017 12:45 AM
dgdgbd
Transmission & Drivetrain
Jul 2, 2011 07:46 AM
Punkfarter
May 24, 2011 12:23 PM
t3601
Dec 3, 2009 01:53 PM
Turbocivic94
Apr 11, 2006 06:53 PM
