GM Synchromesh Tranni Fluid
Old Jun 15, 2002 | 07:58 AM
RedLudeSH's Avatar
Default GM Synchromesh Tranni Fluid
i remember reading something about using GM Synchromesh Tranni Fluid to fix the grinding when gear shifting ... can someone who has tried this comment on this ... thx
GW
Old Jun 15, 2002 | 08:10 PM
Prelude Vtec 23's Avatar
Default Re: GM Synchromesh Tranni Fluid (RedLudeSH)
Hmmmm.....I havent heard about that. But I do know that if you use Redline tranny fluid it can also help stop grinding if it isnt too severe.
Old Jun 15, 2002 | 08:47 PM
EH2DX's Avatar
Default Re: GM Synchromesh Tranni Fluid (Prelude Vtec 23)
what viscosity? that's what i want to know.....
Old Jun 16, 2002 | 07:47 AM
Buckkaaaa!!'s Avatar
New User
Default Re: GM Synchromesh Tranni Fluid (BB1)
hmmm i've heard mixed reactions when it comes to redline. Some people said that the prelude trannies need some friction and that the redline is too smooth. I've stuck with honda MTF but i still get a 5th gear grind when i shift at higher RPMs.... has anyone here tried that GM stuff?
Old Jun 16, 2002 | 02:22 PM
EG8R's Avatar
GW
Yes use that. Honda Tech line has recommended that....
Old Jun 16, 2002 | 07:30 PM
RedLudeSH's Avatar
Default Re: GM Synchromesh Tranni Fluid (mr. skelly)
just to verify ... this GM Synchromesh stuff is ok to put into my 97 prelude SH?? ... into my transmission?? ... thx for the responses ...
GW
Old Nov 1, 2003 | 03:22 PM
kanzenr91si's Avatar
so is this ok to put in an SH? my friend is starting to get that damn 3rd gear grind, and i wanted to make sure this is ok. i dont know if it has any affect on the atts or anything else, preludes not my area of expertise.
Old Nov 1, 2003 | 05:27 PM
bad-monkey's Avatar
yes it's fine.
make sure you get the regular syncromesh and not the friction modified or whatever.
people say good things about, i'll prob throw it in when i take out the tranny this week.
Old Nov 1, 2003 | 07:43 PM
Prelude Styl's Avatar
Default Re: (bad-monkey)
I've had it in my trans for a couple months now and it's the best fluid ever. No grinds, no stiffness into the gears, just smooth sailin'. It's better than redline, or Honda MTF.
Old Nov 1, 2003 | 08:07 PM
AgentUT's Avatar
Default Re: (Prelude Styl)
Yeah I also used it... I didnt notice the biggest difference, but thats just because the Prelude trannies are not the smoothest on the planet.
Old Nov 1, 2003 | 08:33 PM
specalk's Avatar
where do you get it, do you have part number. also how much of it do i need and how much does it cost. ive got moble 1 in mine now and it works good 10w 30
Old Nov 2, 2003 | 06:33 AM
user 9782082308's Avatar
Default Re: (specalk)
Stuff works real good. I like it better than Hondas mtf. You can get it at the Chevy dealership for about $10 a qt. From personal experience, Redline SUCKS!
Old Nov 2, 2003 | 08:39 AM
lmblf8's Avatar
I heard mixed reviews about using this, saying that it'll really only make big differences in GM trannies. Regular tranny fluid already has additives in it, this stuff thins the fluid out even more.
Damnit, I was at a shop yesterday and the guy was explaining exactly why the gears grind and said that adding this wouldn't help it because the gearing is already fucked up from when the driver powershifts.
When powershifting, its okay to pull it out of gear w/o using the clutch but its when the driver tries to put jam it in the next gear w/o that really hurts it; making the spacing between the synchros more farther apart, making it harder for it to go into the right gear and thats what causes the grindage.
he said that the best way to fix this problem is to have a shop take out the tranny and look at it. don't low ball and put in fluid meant for other cars in.
Old Nov 2, 2003 | 12:38 PM
SKDRCR's Avatar
Default Re: (lmblf8)
the gm synchromesh isn't gonna mess anything up
mine still grinds into fifth if i'm high in the rpm band
so if i'm powershifting into fifth (which i rarely do)
i just double clutch it and it goes in smoooooth
Old Nov 2, 2003 | 02:28 PM
KENLUDE97's Avatar
Default Re: (SKDRCR)
GM Syncromesh is GOLD!!!! I really recommend it!!!
I have been running it for arround 2 years and i have had nothing but GREAT luck with it! It took away the 4-5th grind!!! 1st is much smoother....
GET IT AND BE HAPPY!! it is SO worth the $10.
I guess that penzoil has a "knock off" of the GM stuff... I have not tried it so i have no experience. Splurge on the oil
Old Nov 2, 2003 | 02:56 PM
Default Re: (KENLUDE97)
Pennzoil Knockoff
Old Nov 2, 2003 | 07:26 PM
Boostindrvr's Avatar
ok now ive read different things.... should you use gm synchromesh w/ modified friction or the regular gm synchromesh?
Hey prelude styl what do you mean by penzoil knockoff? is there another just like it that i could purchase at say.. autozone?
Thanks
Old Nov 2, 2003 | 07:51 PM
Yes, Autozone exactly It's a yellow Pennzoil bottle called GM Synchromesh. Works beautiful.
Old Nov 2, 2003 | 09:42 PM
Gerhard_001's Avatar
Prelude Styl is accurate in that GM synchromesh is produced by Pennziol/quakerstate. Here is a link for anyone not convinced, this link is from pennzoil/quakerstate. This stuff was designed for GM and Chrysler vehicles for complete seal compatibility. I am not conviced enough to use this stuff on an 'import' vehicle as this formula addivitives comprise seal integrity, this formula is essentially motor oil with a few additives for GM and Chrylser vehicles. Just because you can put it in your car does not make this stuff good. It is like putting power steering fluid in your honda that is for a GM, Chrysler (non-honda) it is not compatibale because of the additives it contains, and comprimises seal integrity. I am also not for Redline as this garbage accelerates synchro wear. I have seen this many times over firsthand. See the problem with Redline MTF is that the coeffiecient of friction (the friction modifier) is too high, the fluid is too thin about the same as ATF. Now if you put ATF in you MT car your tranny synchros are going to wear prematurely. The reason Redline gives the illusion that it shifts better is because the fluid is thinner than the Honda MTF. Fluid too thin and friction modified spells accelerated synchro wear, The friction modified synchro mesh lies in the same boat the redline as it is too thin and is friction modified. You are better off sticking with the OEM MTF and changing it more frquently, or simply put motor 5W30 motor oil in your tranny.
http://www.pennzoil-quakerstat...d.PDF
Modified by Gerhard_001 at 7:01 AM 11/3/2003
Old Nov 2, 2003 | 09:50 PM
SKDRCR's Avatar
Default Re: (Boostindrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostindrvr &raquo;</TD></TR><TR><TD CLASS="quote">ok now ive read different things.... should you use gm synchromesh w/ modified friction or the regular gm synchromesh?
Thanks</TD></TR></TABLE>
regular
Old Nov 3, 2003 | 04:25 PM
Texas Civic's Avatar
Makes you wonder just how different the seals can be. Seems like they would use similar materials in creating transmission seals industry wide. I have seen a couple of posts from guys who have been running the synchromesh for a couple of years without any trouble.
Kwik Kar Lube & Tune here in The Colony, Texas will drain your fluid and refill it with GM Synchromesh for $35 out the door. Took the guy about ten minutes to do the whole job on my Si. Saved me from making a mess and from laying under the car. Normally a manual trans flush and refill is $25 so it's an extra $10 for the synchromesh.
Call around local lube shops to see what they charge. They buy the stuff in large quantities so it doesn't cost them $12 a quart.
Steve
90 Si
Old Nov 3, 2003 | 05:01 PM
KENLUDE97's Avatar
Default Re: (texascivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texascivic &raquo;</TD></TR><TR><TD CLASS="quote">Makes you wonder just how different the seals can be. Seems like they would use similar materials in creating transmission seals industry wide. </TD></TR></TABLE>
You would be really suprized how many differnt types of Rubber that are used for seals. I design differentials For Polaris ATV's and there are countless different types of rubber... Alot of what a manfactur choses is dependant on price.
And yes different oils are more "corrosive" than others.
Old Nov 3, 2003 | 05:25 PM
I'm no tranny expert so it would not suprise me about the seals. Sounds like you have had more experience with them than I have.
I guess the question is, how fast will this possible corrosive effect take to degrade the seals in a transmission. If were saying that a tranny seal will break down after 80k miles instead of 100k miles of use...or is it a case of the seals going bad after 10k miles???
I sent an email to Quaker State's tech group to see if they had any opinions. I'm sure they will give me the usual..."this product should only be used in GM and Chrysler products" to cover their rears.
In a situation like mine, my tranny has 125k miles and grinds in third. As I see it, my options are...live with the grind, have the tranny rebuilt, take a risk on a used tranny, or spend $25 at Kwik Kar for the GM SM.
I guess if all the seals blow out then it will be a good excuse for a rebuild.
Steve
Old Nov 3, 2003 | 06:24 PM
SKDRCR's Avatar
i doubt the regular gm synchromesh would have
any effect on your seals
Old Nov 4, 2003 | 09:30 AM
Ef Whore's Avatar
Default Re: (Gerhard_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">Prelude Styl is accurate in that GM synchromesh is produced by Pennziol/quakerstate. Here is a link for anyone not convinced, this link is from pennzoil/quakerstate. This stuff was designed for GM and Chrysler vehicles for complete seal compatibility. I am not conviced enough to use this stuff on an 'import' vehicle as this formula addivitives comprise seal integrity, this formula is essentially motor oil with a few additives for GM and Chrylser vehicles. Just because you can put it in your car does not make this stuff good. It is like putting power steering fluid in your honda that is for a GM, Chrysler (non-honda) it is not compatibale because of the additives it contains, and comprimises seal integrity. I am also not for Redline as this garbage accelerates synchro wear. I have seen this many times over firsthand. See the problem with Redline MTF is that the coeffiecient of friction (the friction modifier) is too high, the fluid is too thin about the same as ATF. Now if you put ATF in you MT car your tranny synchros are going to wear prematurely. The reason Redline gives the illusion that it shifts better is because the fluid is thinner than the Honda MTF. Fluid too thin and friction modified spells accelerated synchro wear, The friction modified synchro mesh lies in the same boat the redline as it is too thin and is friction modified. You are better off sticking with the OEM MTF and changing it more frquently, or simply put motor 5W30 motor oil in your tranny.
Modified by Gerhard_001 at 7:01 AM 11/3/2003</TD></TR></TABLE>
He's wrong about the Friction modified....it works great, just like the non-friction.
