Alright Honda Tech I Need Some Help
I have a 94 dx coupe with a b16a2
ive got it completely wired up using a obd2 converted delsol harness
but im not getting any power anywhere
im thinking im missing grounds somewhere
what grounds are there that i could be missing or any other problems that could cause this
im stumped
im stumped
main ground could cause, it so can a dead battery........................just so ya know im starting with the REALLY REALLY obviuos ****, happens when you go really into a car and you overlook the obvious lol i hate that!
nope thought that too
but i just got a new battery 30 min ago and was just trying
(i dunno why i like doing all my car work at 2 am but it works lol)
oh that ground lol
i forget wiring easy
yep conected although there is a second ground i noticed today but i dunno where it leads to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">the most important one is all of them</TD></TR></TABLE>
fixed
fixed
follow the lower radiator hose from the radiator to the motor, where the lower radiator hose ends is the thermostat housing, you should see i think 3 ground wires attached to an eyelet if they aren't hooked up there is a threaded hole on top of the thermostat housing where they get bolted to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanegb16 »</TD></TR><TR><TD CLASS="quote">
but im not getting any power anywhere</TD></TR></TABLE>
i did this one on a 94 del sol that had the harness cut out when some JACK A** stole the ecu. we too the obd1 ecu harness out of a crunhed integra and i cut it from the cabin harness and put it in the del sol. you shouldn't have to cut more the three wires the ecu should have wires that run from strut tower connector to the ecu UNCUT and three you cut from the body harnness. One is the diagnostic wire (go's to ground to make CEL blink codes) one for the CEL so the ecu can tell you there is a problem. (it'a just a 12V out put from the ecu) and the 12V power in from the Key. (turns on the ecu). and thats it.
things to look for
1. none of the wires are cut at all (even when the soiderd that might not work right)
2. does the CEL come on when you turn the key. If No Does Any thing turn on???
3. is it a OBD1 To OBD2 Intercont or did you rewire it to the OBD2 plugs (ie Pin swapping Not Cut and Crimp)
if it's a rewire/Cut and Crimp did you get all the pin in the right spots on the new connectors?
i have fixed ALOT of the cut and crimp/repin's and it's just ezer to just do the strut conector to ecu harnes with the 3 wire connection then to repin cheaper to whe you remember if you connect the pins wrong you can fry the ecu and all the sensors.
things to look for
Maybe you can help me with my car...i have no cel or battery light or the other lights tht turn on when i try to start the car.
im still running a p28
i just converted the injector, dizzy, and alternator plugs to go with my b16a2
i would check the cel but like i said no power at all
no lights nothing
no lights nothing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanegb16 »</TD></TR><TR><TD CLASS="quote">no no no lol its still and obd1 harness with the dizzy etc converted to obd2 </TD></TR></TABLE>
ok obd1 ECU Trying to run OBD2 DIZZY......
NOT GOING TO WORK it's like trying to talk your way out of a ticket from a Mexican cop when all you know in spanish is F'U cork sucker.
cdj2386
May 16, 2008 02:18 PM
