crank pulley is still wobbling!
Old Sep 3, 2007 | 10:25 PM
badassmthr4000's Avatar
Default crank pulley is still wobbling!
alright ive had this jdm h22 for only 600 miles now and have been real gentle so i can break her in. i swaped it into my SH prelude so as most no i took things from my old motor that were crank related. well the reason i decided to do the swap was because my old motor was shooting crank pulleys off. weard i no but i decided to jus say screw it after the 4th pulley and buy wat i was already looking into buying. so ya 600 miles later this jdm h22 is beginning to do the same sequence as my old motor jus before it started eating crank pulleys. i was wondering if the crank bolt loosining up could have to do with vibration somewere? if so were? could the fact that i have the balancer pulley and timing pulley from the old motor on this one, do to the needs of the crank sensors have anything to do with it? thanks in advance!
Old Sep 3, 2007 | 11:06 PM
CHK4TIX's Avatar
Default Re: crank pulley is still wobbling! (badassmthr4000)
I dont know what is causing your problems, but why are you breaking in a JDM engine? did you rebuild it or something? if its just your typical h22a, the previous owner broke it in during that 30k-60k miles it was in the car in japan
Old Sep 4, 2007 | 03:00 AM
UK_Luder's Avatar
Are you tightening the crank pulley up to the correct torque each time (220Nm)?
Old Sep 4, 2007 | 08:53 AM
axlline's Avatar
So you took crank parts out of a h22a4 that was spitting pulleys and put them in your h22a?And now your h22a is spitting pulleys?
DJNauTicz
May 2, 2007 11:31 AM
ilovemydc5
Feb 2, 2007 01:24 AM
RTW DC2R
Feb 11, 2005 05:18 PM
RAB
Oct 13, 2004 05:45 PM
Turbolude
Sep 12, 2001 05:53 PM
