b18b head with b20z head and other mods,will this work?? and yes i searched
ok im in the process of getting a motor together and im using all spare parts i have lying around, so heres the run down let me know if this will be ok..
b18b block stock bore and crank
gsr rods
pr3 pistons
gsr wather pump and oil pump
gsr timing belt?/
and all new gsr bearings??
with a b20z2 head..
so will this work together not looking for a lot of power just a decent low buck motor for my hatch,,lmk wat you guys think
gsr rods
pr3 pistons
gsr timing belt?/
with a b20z2 head..
If by B20Z2 head you mean P8R head, it'll work, mostly, except that the combustion chambers have an 84mm diameter, while your cylinders have an 81mm diameter. Not the best option. Search for P8R head or something for more info on that. Also what Chris said, you can't use those rods with that crank. However, I BELIEVE you can swap in an ITR or GSR crank, which then of course would let you use those rods, but bust out your calculator to make sure everything fits right before doing that.
Well, you'll have to do some searching to see exactly what's required, as far as any modification to the block (if any) and what kind of piston-valve clearance you'll be seeing. Online compression ratio calculators will give you some idea of this, but you'll have to dig through the archives too. Search for both of these, plug in your numbers/parts and see what you get. The calculator remark was for the math involved with stroke and so forth to see if that setup would have the pistons punching through the compression chamber in the head.
I also remember them being used, but it's been awhile since I was certain of the details, and I don't want to tell you the wrong thing. I would find out about how the pistons will be positioned with respect to the combustion chamber though.
4drhoar
May 31, 2009 06:28 PM
EJgsr
Nov 16, 2006 12:05 PM
allmotorej8
Sep 28, 2005 08:15 PM
