Oil on the plugs...
Old Sep 3, 2007 | 08:23 PM
sedlmeier101's Avatar
Default Oil on the plugs...
Changed the spark plugs yesterday, have a few questions. The original plugs were gapped .045
But I read on here with my set up I should be runing around .030 so that is where I gapped them to, should this be okay?
Also the plugs in cyl. 1 and 2...there was some oil on the plugs.. should I be worried? The plugs were deffintly foulded out, my car is in need of a tune. running very rich.
Old Sep 3, 2007 | 08:57 PM
yoffer's Avatar
Banned
They're supposed to by gapped at .043. Why would you change it? You made the gap smaller, thus less spark. Leave it at stock gap and forget about it.
Old Sep 3, 2007 | 09:36 PM
energ3tic2's Avatar
oil on plugs can be a bad sign
Old Sep 3, 2007 | 11:10 PM
vietfella's Avatar
Default Re: (energ3tic2)
oil in the plugs may mean your gasket at the plug may be bad.. might want to replace them.
Old Sep 3, 2007 | 11:21 PM
smileycvc's Avatar
Default Re: (vietfella)
Was the oil on the tip of the plug? If so you might have problems. Do a compression test and let us know what you get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietfella &raquo;</TD></TR><TR><TD CLASS="quote">oil in the plugs may mean your gasket at the plug may be bad.. might want to replace them. </TD></TR></TABLE>
If there is oil on the tip his rings could be bad. I think you are talking about the gaskets that go on the valve cover. They will keep oil from going down the spark plug hole, but oil still wouldnt reach the tip.
Old Sep 4, 2007 | 12:52 AM
forcefedferio's Avatar
Default Re: (smileycvc)
are you running a forced induction set-up? if not stick with the stock gap.
and like smileycvc said the location of the oil on the plug is important
Tip of plug=bad
Top of plug= not so bad, $20 valve cover gasket set will fix.
Old Sep 4, 2007 | 07:38 AM
Default Re: (forcefedferio)
Yes, I am running a FI setup. t3t4 turbo on stock internals set at 8lbs right now.
The oil is on the side of the plug (where the wrench is used to tighten the plug)
The actual bottom of the plug is just dark colored..Due to how rich my car is.
I closened the gap on the plugs because I read somewhere that running a FI setup causes a need for a smaller gap.
Will I hurt anything by going with a .030 gap?
Old Sep 4, 2007 | 08:09 AM
akunamatta's Avatar
* B A N N E D *
or the valve guide seals could be bad.
Old Sep 4, 2007 | 08:43 AM
Default Re: (sedlmeier101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedlmeier101 &raquo;</TD></TR><TR><TD CLASS="quote">Will I hurt anything by going with a .030 gap?</TD></TR></TABLE>
no you won't, the gap on my blue car is set at .028.
Judging by where the oil is, you just need a valve cover gasket set....and get that thing tuned! that's why you're fouling plugs out, are you just running a basemap of some sort?
Old Sep 4, 2007 | 09:15 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
oil on the "outside" of the plugs, meaning the side without the electrode, is almost always bad spark plug tube seals. Very easy, cheap fix.
BBallz24
Feb 16, 2009 06:17 PM
LAO
Dec 14, 2007 07:36 PM
Midori Green
15
May 25, 2007 12:39 PM
B2FiNiTY
Jul 9, 2003 03:41 AM
PressurizedSi
Nov 29, 2002 03:48 AM
