stock d16z6 rattles at 4th and 5th 2400rpms?
Old Sep 3, 2007 | 08:05 PM
vdub08's Avatar
Default stock d16z6 rattles at 4th and 5th 2400rpms?
bought a new ej1 last month completely bone stock. so far all i've done is add a front and rear strut bar and swapped the intake twice.
originally driving the car home (about 40 miles) i never heard a thing. drove it around for a little more and i didnt hear anything..
then i dropped in a cai, i was missing the bottom bushing, but i did not think it was going to be an issue. drove the car and i noticed a rattling noise at 2400 rpms in 4th and 5th. it would sound normall, then once it passes 2400 in either gear, the rattling becomes very noticable.
this cai was temporary anyways because i needed to repaint my plastic dork. Repainted it and dropped it in. it barely fit. actually the intake mani coupler doesnt even fully mate, but it mates enough for me to tighten the coupler tie. the other end is rubbing on the abs fuse box and the middle is rubbing the abs wiring.
again, once i shift into 4th and hit the 2400 mark, it rattles
then again in 5th at the same rpms
any idea? it's a very hollow rattle, like if there was a nut rolling around behind the door of the throttle body
Old Sep 3, 2007 | 08:46 PM
95jdmcivic's Avatar
could be your transmission
Old Sep 3, 2007 | 08:53 PM
CapnKrunch's Avatar
Default Re: (95jdmcivic)
It sounds like it could also be your exhaust. My exhaust makes a similar rattling noise at about the same RPM.
Old Sep 3, 2007 | 09:25 PM
instrument's Avatar
wow, diagnosing rattles!!! this is awesome.
i'm gonna say its your _______ mount.
or maybe your __________ shaft
seriously, get in your engine bay and tighten **** till it goes away, there's not much we can do out here on the "internets"
Old Sep 4, 2007 | 11:23 AM
vdub08's Avatar
i really dont know what it is, but i dont think it's my exhaust mounts because i noticed it only happens when i step on the gas
and if it was a loose bolt wouldnt it rattle all the time?
and it's not really a rattle because the word rattle kinda implies high pitched. but it's sort of a humming chatter
Old Sep 4, 2007 | 01:05 PM
eJone powereD's Avatar
Default Re: (vdub08)
could be the heat shield on your catalytic converter
Old Sep 4, 2007 | 02:38 PM
vdub08's Avatar
i've had a broken exhaust bracket before, and that rattle never responded like this one.
this one rattles when i put the foot on the throttle, and stops when i let go. it's like something is wrong with the intake mani
Old Sep 4, 2007 | 05:01 PM
03akkord5spd's Avatar
does it rattle just in gear or in neutral also? if it does it in neutral, pop your hood, get someone to rev it to that rpm while you're under the hood diggin around...
Old Sep 4, 2007 | 09:49 PM
vdub08's Avatar
only in 4th and 5th
kornerk12
Apr 22, 2007 03:47 PM
mgags7
Oct 3, 2005 07:16 PM
AndyD
May 29, 2005 06:33 AM
Log4n
Dec 13, 2003 09:00 PM
BrianBB6
Jul 1, 2001 08:21 AM
