Welding cylinder size?
Old Sep 3, 2007 | 07:08 PM
HiPsi's Avatar
Default Welding cylinder size?
Huys, I just bought a 180 amp lincoln welder, and I need a gas cylinder. I was just wondering what you guys use or recommend. Also, what kind of time frame are you looking at per cft? I suppose that may vary with the type of gas.?. Thanks
Old Sep 3, 2007 | 07:27 PM
ROTARY's Avatar
Default Re: Welding cylinder size? (HiPsi)
is this welder a tig or mig? because tig uses a lot more gas so i would recommend you at least get a 110CF tank.
when i had a 50CF tank i had to get it filled just about every week.
Old Sep 3, 2007 | 07:29 PM
HiPsi's Avatar
Default Re: Welding cylinder size? (ROTARY)
Dang, knew I was forgetting something. It is a mig.
Old Sep 3, 2007 | 07:32 PM
ROTARY's Avatar
if you don't weld everyday a 80CF bottle is a good size and should last you a few months.
Old Sep 3, 2007 | 07:47 PM
HiPsi's Avatar
Default Re: (ROTARY)
Sweet. Thanks for the fast response!
b16bri
Welding / Fabrication
Nov 20, 2011 01:09 PM
SQ is the SQUAD
Feb 16, 2011 09:59 PM
zurud
17
Jun 18, 2009 10:45 AM
M3Stylz
Jan 12, 2008 05:47 AM
HCJDM1
Apr 4, 2007 01:02 PM
