best strut /sway bars
Old Sep 3, 2007 | 06:06 PM
BrianB18's Avatar
Default best strut /sway bars
i just bought a '98 coupe and i was wondering which strut and sway bars handle best on it.
thanks
Old Sep 3, 2007 | 06:08 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: best strut /sway bars (BrianB18)
For front upper shock tower bars the password:jdm and the Carbing piece are nice.
The carbing is about $450 and the pw:jdm one is about $250-300 I think.
As far as the rest, just go with a name brand. If you don't have sway bars get those first.
a 22-23mm in the rear and a front sway bar appropriated to your driving will do you the bes.t Do a search for "sway bars" and find some comparison threads and see what people like.
97Ej6mike's Avatar
Really comes down to customer claims.
Personally i like my nuespeed front upper strut bar, nice solid one-piece design, but i do fancy ( yes i said fancy) the 3-point strut tower bars that Password makes.
As for a sway bar, you have a few choices, such as OEM (jdm type R's), Nuespeed, comptech, ST.suspension, ect.
If you do plan on doing a rear swaybar, you will need to consider a comptech or ASR subframe plate/reinforcment kit, cause it can and will tear out the subframe holes.
Old Sep 3, 2007 | 06:11 PM
Ek Forever y0!
Default Re: best strut /sway bars (akunamatta)
Actually, what do you have done to your car now? Is it stock?
If so akuna is right, you'd benefit more now with a good set of springs/coilovers and shocks.
Old Sep 3, 2007 | 06:12 PM
BrianB18's Avatar
Default Re: (97Ej6mike)
yeah i looked on password but they are out of stock on half their ****. i was going to get that Bronze 3-piece, but other then that does it really make that much of a difference which brand you get? i just want a good quality bar
Old Sep 3, 2007 | 06:16 PM
akunamatta's Avatar
* B A N N E D *
Default Re: best strut /sway bars (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Actually, what do you have done to your car now? Is it stock?
If so akuna is right, you'd benefit more now with a good set of springs/coilovers and shocks.</TD></TR></TABLE>
x2, i have heard rumors about 22mm + sway bars causing sub frame tear on factory suspended eg's/ eks/ and dcs without appropiate precautions...
Old Sep 3, 2007 | 06:17 PM
brian_98EK's Avatar
Default Re: (BrianB18)
sorry that was my old name and i accidentally logged on, on it
but i bought my coupe on **** sleeves and last night i ordered OMNI coilovers for it
Old Sep 3, 2007 | 06:18 PM
Ek Forever y0!
Default Re: (brian_98EK)
If you do get a sway bar make sure to the the ASR subframe brace. Do a search for "sway bar"
And you'll find tons of info about sway bars.
Old Sep 3, 2007 | 06:19 PM
akunamatta's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian_98EK &raquo;</TD></TR><TR><TD CLASS="quote">sorry that was my old name and i accidentally logged on, on it
but i bought my coupe on **** sleeves and last night i ordered OMNI coilovers for it </TD></TR></TABLE>
in this case go by what ekforeverguy said..... however start with the sways they will give the most noticeable upgrade.
"For front upper shock tower bars the password:jdm and the Carbing piece are nice.
a 22-23mm in the rear and a front sway bar appropriated to your driving will do you the bes.t Do a search for "sway bars" and find some comparison threads and see what people like."
Old Sep 3, 2007 | 06:21 PM
Archidictus's Avatar
Unceasing Measure
Neuspeed four-point front upper strut brace - cheap on eBay ($80 or less) and it'll do more for turn-in and stability than many more expensive bars.
Suspension Techniques makes the most user-friendly set of swaybars for the EG because they use heavy bolt linkages rather than the shitty Honda endlinks that break when you look at them funny. Also, they don't require aftermarket or swaybar-friendly LCAs. With the heavy bolt linkages you can adjust preload with an impact gun to suit your driving style.
Then again, if you have to ask a question like this, I assume you don't know what constitues "good handling" or the physics behind it, so it's really a moot point.
Old Sep 3, 2007 | 06:24 PM
brian_98EK's Avatar
Default Re: (akunamatta)
i have searched only for strut bars but didnt get anything. as far as strut goes im looking at getting either Spoon or Tein's if i cant get the password one.
and thanks alot ill go look at some of those threads and see what looks best
Old Sep 3, 2007 | 06:58 PM
spock_rocker's Avatar
memoryFAB.com representative
i think any strut bar will work, ive used 2pt and 3pt bars, and i dont see much of an advantage of a 3pt unless your doing autox or track stuff.. or atleast thats why i have one. now sway bars are a different story. your coupe already has a 23mm in the front i do believe, and nothing in the rear.. might i suggest a 19mm and a subframe reinforcement kit. its a good base until you learn the limits and decide your plans for the car. just an idea.
Old Sep 3, 2007 | 07:03 PM
Eran's Avatar
HT White Ops
H&R makes a 17mm, Cusco makes an 18mm, and Suspension Techniques makes a 19mm.
Those are all very good beginner bars.
Old Sep 3, 2007 | 07:07 PM
brian_98EK's Avatar
Default Re: (Eran)
i made up my mind and ordered the Suspension techniques say bar system including tie bar. im happy with what i decided.
but i dont autocross so do i need a reinforcement kit?
Old Sep 3, 2007 | 07:12 PM
akunamatta's Avatar
* B A N N E D *
yeah, the ASR SFB is well worth the peace of mind.
Old Sep 3, 2007 | 07:16 PM
brian_98EK's Avatar
i think im going to get it a little later so i can atleast buy some gas and make insurance payments but i will for sure look into it
Old Sep 3, 2007 | 08:51 PM
CirCus's Avatar
* B A N N E D *
Carbing for sure, if not that then JDM Type R's are dope to
Old Sep 3, 2007 | 09:32 PM
bmoua's Avatar
i'd pick up a ebay SPECIAL $20 front strut bar and use the other $280+ else where.
Dubs13
Suspension & Brakes
11
Jun 22, 2008 04:56 PM
Brown-tec
Oct 30, 2005 06:51 PM
Greg James
Jul 30, 2004 12:55 PM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
