M Factory 4.92 Final Drive Question...
Old Sep 3, 2007 | 05:11 PM
PowerSpeed Motorsports's Avatar
Default M Factory 4.92 Final Drive Question...
I purchased a 4.9 final drive set from M Factory and was having a problem installing it. I have a GSR transmission and put a 4.78 F.D. from a JDM Type R first. When I tried to install the 4.9 F.D. it wouldn't work unless I put the GSR 1st gear back instead of the Type R 1st gear. Does this sound right. I just want to make sure before I destroy a tranny. Any advice is well appreciated. Thanks.
Modified by PWRSPDEG at 8:16 PM 9/3/2007
Old Sep 4, 2007 | 07:20 AM
MFactory's Avatar
The final drive you ordered was designed for the USDM transmission, thus you have to use the GSR (or USDM ITR) 1st gear with it.
The JDM '98 spec Final Drive that you had uses a different 1st gear, hence why it will not fit.
Thanks
Old Sep 4, 2007 | 04:37 PM
Default Re: (MFactory)
Thanks for your response. We figured that was what we needed to do and did put the GSR 1st gear back on . Thanks. Can't wait to try it out.
d-yup
Transmission & Drivetrain
Feb 10, 2010 10:37 AM
VtecSyndrome
May 4, 2008 06:58 PM
.1type.
Jun 28, 2005 11:32 PM
