Is the 90-93 exhausts the same for 2 doors and 4 door?
Old Sep 3, 2007 | 03:45 PM
tdesi420's Avatar
Default Is the 90-93 exhausts the same for 2 doors and 4 door?
like the title says, does anyone know if the 2 door cat-back exhaust will fit on a 4 door?
Thanks
Old Sep 4, 2007 | 04:21 AM
tdesi420's Avatar
any1 know??
Old Sep 4, 2007 | 02:55 PM
92 AccordLX's Avatar
Default Re: (tdesi420)
It depends on the motor code.
Old Sep 4, 2007 | 03:21 PM
JDM_DC4_Fanatic's Avatar
Default Re: (92 AccordLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 AccordLX &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the motor code.</TD></TR></TABLE>
no it doesnt. the motors share the same exhaust. the 2dr exhaust is slightly shorter due to the shorter wheel base.
ETA: if you are modding a 2dr exhaust, you can always lenghten the pipe to make it fit. just cut the flange off that connects to the catalytic converter and extend it to the right length, then have a muffler shop weld in the new pipe and flange
Old Sep 4, 2007 | 05:48 PM
tdesi420's Avatar
thanks, i have a 4 door 1992 stock LX....got someone selling an exhaust setup from a 2 door and wanted to know if it would fit directly....so in that case, if i did get the exhaust, i would have to make the piping longer?
Old Sep 4, 2007 | 06:46 PM
flowercake123's Avatar
Default Re: Is the 90-93 exhausts the same for 2 doors and 4 door? (tdesi420)
They are different.
Old Sep 6, 2007 | 06:50 PM
tdesi420's Avatar
Old Sep 8, 2007 | 09:17 AM
fleetw00d's Avatar
Default Re: (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
According to my 93 Accord service manual, wheelbase is the same for 2 door, 4 door, and wagon (should be true for 90-92 as well). Majestic Honda lists same product number for 2 and 4 door B pipe and muffler for 92 Accord LX.
Old Sep 8, 2007 | 10:42 AM
GhostAccord's Avatar
Default Re: (fleetw00d)
Honda Part numbers are exactly the same for both the 2 door and 4 door from the Cat Back. There are only the two parts the B Pipe and the over axle pipe with muffler.
So to answer your question yes the exhausts are interchangable from the cat back.
Before the cat is where there is a difference between the EX and DX-LX's. The EX has a 4-2-1 style exhaust. Where the exhaust manifold/ header dumps into a double down pipe then into a single pipe under the engine. Similar to an after market header. The DX & LX's have a 4-1 system where the 4 exhaust ports all collect in the manifold and dump into a single down pipe.
JDM-JAMES
Mar 9, 2009 06:16 PM
tdesi420
Sep 6, 2007 08:32 AM
bankhead83
Nov 8, 2004 05:46 AM
SMC Integra
May 27, 2004 11:39 AM
hicamjunkie
Mar 1, 2004 10:53 AM
