OBD0-OBD1 engine harness conv...Checking ecu code?
Old Jun 15, 2002 | 02:40 AM
NipponRacing's Avatar
Default OBD0-OBD1 engine harness conv...Checking ecu code?
I rewired my 89 civic to OBD1 ecu (p28) and there is a check engine light on. How do I check the code?
Old Jun 15, 2002 | 08:22 AM
Blown90hatcH's Avatar
Default Re: OBD0-OBD1 engine harness conv...Checking ecu code? (NipponRacing)
Where did you get the conversion harness from?
Old Jun 17, 2002 | 03:16 PM
b16aeg6's Avatar
on the conversion harness there should be a toggle switch. if there is you switch it one and it will check the codes. if not you ground out obd1 wire d4 to the frame and it sould pull the codes. good luck.
Old Jun 18, 2002 | 01:10 PM
Malgerus's Avatar
Default Re: OBD0-OBD1 engine harness conv...Checking ecu code? (Blown90hatcH)
heh, I made mine
Anyways, to check the code (with OBD-I) all you have to do is get a piece of wire or a paperclip and bridge the service connector on the driver side of the engine bay. It should have a yellow cap on it. Turn the key to the "on" position, but don't start the car. The check engine light will then blink whatever code it is you have.
Old Jun 18, 2002 | 05:49 PM
StorminMatt's Avatar
Default Re: OBD0-OBD1 engine harness conv...Checking ecu code? (89_Y_49)
Actually, it depends on how you rewired. If you used my guides, then you do indeed chort out the service check connector. But other people probably deal with this in different ways.
existanzcivicb20
20
May 22, 2017 04:23 PM
91 DA Revived
Aug 22, 2010 10:34 AM
n*werk
24
Feb 26, 2009 06:06 AM
si 1
Mar 31, 2006 12:35 PM
turboex
Jun 13, 2002 05:34 PM
