how to repair key scratches?
Old Sep 3, 2007 | 02:14 PM
greenEFSI's Avatar
Default how to repair key scratches?
what is the proper way to repair a car that has been keyed? keep in mind it is going to get repainted .also do sand the car down and fill in the scratches in with body filler?
Old Sep 3, 2007 | 04:26 PM
powerflow's Avatar
Default Re: how to repair key scratches? (greenEFSI)
Depends on how deep the damage is. Its pretty easy if its not scraped down through a few paint jobs and gouged, dented up the metal. Remove/ feather out w/ 120-180, fill any imperfections that won't level out in the primer, finish and feather out w/ 320, prime, prep, paint. Just make sure you block it correctly with the true level profile of the car. If its not too deep, just sanding and priming will work. Use a good 2k high build primer and properly cure it before prepping.
Old Sep 4, 2007 | 12:09 PM
greenEFSI's Avatar
Default Re: how to repair key scratches? (powerflow)
sounds good thanks alot
danteisme
Paint and Body
Feb 11, 2019 08:56 AM
-16V-
Paint and Body
Mar 23, 2009 02:56 PM
SLO Sol
Paint and Body
Nov 1, 2007 07:13 PM
prod19y
Feb 14, 2003 04:25 AM
