what spark plugs to use?
Old Sep 3, 2007 | 11:13 AM
em1si's Avatar
Default what spark plugs to use?
i've got ls/vtec in my car and i'm trying to find out which new spark plugs to order...i know i prolly shouldn't use the craptastic ones that they use stock on a gsr...so here's the run down
b18a1 block
bored out to 82mm
12:1 compression
gsr head stock valvetrain
plus a lot more, but i think that's the essentials for which plugs i need to know...
i don't understand about how or why to go hotter or colder or whatever with plugs, so if u could explain why some are better than others, i would greatly appreciate it...thanks in advance guys
Old Sep 3, 2007 | 11:54 AM
flatblack-h22's Avatar
Default Re: what spark plugs to use? (lsvtec-sleeper)
colder plugs are related to F/I motor to my knowledge
Old Sep 3, 2007 | 12:05 PM
madpipr's Avatar
Default Re: what spark plugs to use? (Mr.EGG)
New NGK V-power BKR6E spark plugs (stock LS pistons)
NGK V-power BKR7E spark plugs for 10.0-12.0:1 compression
NGK V-power R5671A-8 plugs for 12.0:1+ compression
https://honda-tech.com/zerothread?id=1676914
from that thread- its a great thread
Old Sep 3, 2007 | 12:12 PM
3lo's Avatar
3lo
anyone tried these ?
Old Sep 3, 2007 | 12:13 PM
em1si's Avatar
do u know why these are good? other than just some guy stating it? thanks for the replies
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec-sleeper &raquo;</TD></TR><TR><TD CLASS="quote">
i don't understand about how or why to go hotter or colder or whatever with plugs, so if u could explain why some are better than others, i would greatly appreciate it...thanks in advance guys</TD></TR></TABLE>
Proper heat range is important so you don't detonate (ping). Use a hot plug on a n2o or turbo, you might just turn that plug into a glow plug and gases will burn when you don't want them to. you want the plug to get to a certain temp and stay there keeping the electrode clean and preventing ping. at least two steps colder when turbo or n2o. higher the # colder the plug. also go colder when raising compression.
Old Sep 3, 2007 | 12:19 PM
em1si's Avatar
now that makes sense..
so can anyone tell me for 12:1 compression if the above mentioned plugs are correct for me, or what people with similar setups are running in theirs and how they work for them?
Old Sep 3, 2007 | 12:22 PM
THC07's Avatar
Default Re: (lsvtec-sleeper)
use BKR7E-11 for you colder plug.
Old Sep 3, 2007 | 12:23 PM
em1si's Avatar
k...thanks
sneakychaos
Nov 8, 2008 04:47 PM
I got a honda
Aug 2, 2005 04:46 PM
MenaceL.A.671
Aug 1, 2005 09:32 PM
tnbigdawg
Dec 23, 2002 02:41 PM
OneThirtyEight
Dec 27, 2001 09:19 AM
