Axle Question
Old Sep 3, 2007 | 08:45 AM
evil sol's Avatar
Default Axle Question
My girlfriend just had her axles replaced about a month ago.
Now my question is what could cause the new boot to crack?
The boot that cracked is the passenger side closest to the wheel.
Could the car be too low?
Could she be going over speed bumps to hard?
Can I just replace the boot and not the entire axle?
Thanks.
Old Sep 3, 2007 | 09:06 AM
sicones's Avatar
Default Re: Axle Question (evil sol)
inferior aftermarket parts
Old Sep 3, 2007 | 09:11 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil sol &raquo;</TD></TR><TR><TD CLASS="quote">My girlfriend just had her axles replaced about a month ago.
Thanks.
If you catch it early enough, usually, but that's doubtful - you're better off just replacing the whole axle.
Old Sep 3, 2007 | 11:52 AM
evil sol's Avatar
Default Re: Axle Question (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
If you catch it early enough, usually, but that's doubtful - you're better off just replacing the whole axle.</TD></TR></TABLE>
think i have a 3 month warrenty still so i can get it replaced.
Old Sep 3, 2007 | 12:36 PM
maxpsi's Avatar
Most auto parts stores have warranties on the axles they sell.
As to your question about how the boot may rip, there are a few causes. The grease inside the axle can vaporize and cause pressure against the boot. DSS solved this problem by adding a vent to release that pressure. Road debri can also hit the boot and tear it that way.
It is possible to replace just the boot, but who says the axle wasn't damaged when their was nothing to keep the grease around the joint.
Old Sep 3, 2007 | 12:56 PM
evil sol's Avatar
Default Re: Axle Question (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">Most auto parts stores have warranties on the axles they sell.
It is possible to replace just the boot, but who says the axle wasn't damaged when their was nothing to keep the grease around the joint. </TD></TR></TABLE>
there is grease in the boot. how much i dont know. but did feel grease in the boot.
lots of grease on the inner wheel. though.
Old Sep 3, 2007 | 05:53 PM
2wheelhunter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">inferior aftermarket parts </TD></TR></TABLE>
x2
happened to me too
Old Sep 9, 2007 | 06:16 PM
evil sol's Avatar
Default Re: Axle Question (2wheelhunter)
found out that my girlfriend ran over a branch that cut the boot.
so all is well after getting the axle replaced.
kenzo42
Apr 18, 2009 06:50 PM
honda3431
Jan 20, 2007 09:00 AM
driftmaster04
May 3, 2006 11:07 PM
zero808
Mar 2, 2006 07:43 PM
lahight
Sep 3, 2003 01:26 AM
