check engine light problems
Old Sep 3, 2007 | 07:53 AM
vaerio81's Avatar
Default check engine light problems
ok so i need some help with this.........i just had a b16 put into an 92 hatch and everything has been good but for a while now the check engine loght comes up........if im driving in the city i could be driving for a long time and nothing happens i can even hit vtech and push the car and nothing happens but when i go on the e-way the check engine light comes on........i could stay at normal rpms or rev high and the light comes on no matter what when im in the e-way .......i thought it was a tune up so i changed the spark plug wires and the spark plugs , the cap and the rotor and still the same ........i need to change the fuel filter cuz im not sure when was the last time the filter was change...........oh one more thing when i turn off the car and turn it back on the light turns off untill ill hit the e-way again......any info will be appreciated.....thanks!
Old Sep 3, 2007 | 08:00 AM
lsdB16aEj1's Avatar
Default Re: check engine light problems (vaerio81)
https://honda-tech.com/zerothread?id=682412
This will tell you how to read it and tell you what the code your getting is for
Old Sep 3, 2007 | 10:23 AM
vaerio81's Avatar
Default Re: check engine light problems (lsdB16aEj1)
thanks dude i just found that link too hopefully i can get that solve ........
Cody Anderson
Aug 18, 2014 03:35 PM
alfiler
Feb 16, 2009 11:55 PM
LSxVQ35
Sep 10, 2008 05:31 AM
Ed 341
Mar 8, 2006 02:45 PM
TurboTurtleGSR
Sep 21, 2002 08:26 AM
