99 Accord Coupe V6 - CEL with P0181
Old Sep 3, 2007 | 06:45 AM
ultragc's Avatar
Default 99 Accord Coupe V6 - CEL with P0181
Hi All,
Just failed the smoke check on my 99 Accord V6 Coupe. The mechanic said that I have a "P0181 Fuel Temperature Sensor A Circuit Range/Performance". However, it looks like Honda does not even have this code. What gives? My smoke check is due in early October and I am starting to worry.
Any suggestions?
Thanks all.
Old Sep 3, 2007 | 11:55 AM
ultragc's Avatar
Default Re: 99 Accord Coupe V6 - CEL with P0181 (ultragc)
update...
I use my friends Auterra Dyno-Scan to check again. It can back with P0420 Catalyst System Efficiency Below Threshold (Bank1). This look like an O2 sensor... but what is Bank1?
Old Sep 3, 2007 | 11:58 AM
YeuEmMaiMai's Avatar
check out your catalytic converter before you replace any sensors. it is a high failure rate on this generation of v6 accords
Old Sep 3, 2007 | 01:24 PM
ultragc's Avatar
Default Re: (YeuEmMaiMai)
Thanks for the comment. I thought the same thing but it is going to cost buku $$$.
92integraVTECgsr
Feb 17, 2025 01:08 PM
kevkru
May 10, 2015 10:36 PM
tehmole
Jun 4, 2009 07:44 PM
HLee628
Audio / Security / Video
Aug 19, 2003 11:46 AM
