gettin out of the game, take my car and all my parts like ls motors for $2000 OR BEST OFFER!
Ok, Unfortunitly i need to sell my baby. Im moving on to bigger and better things. She has been my pride and joy over the past few years but times have changed. Without further B.S. heres the info on the car
-1989 Honda Civic Si
-d16a6 Motor, (SOHC NON-VTEC)
-Ram Air Intake (EBAY)
-Spoon Sports Header
-Custom Test Pipe
-Invidia Cat-Back Exhaust (crx version, custom to hatchback)
-Xenon Blue Headlights
-Sparco Sprint Seat on custom bracket
-Skunk2 Coilovers
-Eg Rad Gangster lean (was gonna go turbo)
-Autometer Carbon Fiber Air/Fuel Ratio Gauge
-Skunk2 Short Shifter
-Autometer 5 inch Tach with Shiftlight (make keep)
-Integra type r shift boot (real)
-KNock off civic type r shift ****
-Urethane shifter bushings
-Tow Hooks (front and back)
-NGK Plugs and Wires
-New Cap, Rotor, Distributor
-New Water Pump
-New Timing belt
-New Head Gasket
-New Valve Cover Gasket
-Custom Shaved and Painted Valve Cover
-Front and Rear Upper Strut Tower Bars
-New Clutch (oem)
-Password JDM Amber Corner Lights
-Mild Wire tuck on one side
-Sparco Steering wheel with quick release hub
-Ichibahn Pedals
-CRX SI rims with brand new tires
-75000 miles on fresh rebuild
-185000 on car, gauge cluster is not from the car.
Thats all i can remember thats on it. But i got a ton of parts ill give with the car when it is bought.
COMES WITH CAR!
-Acura Integra LS Motor, torn apart and looked at by pro mechanic. Real good shape.
-New Rotors and brake pads
-New Axles
-MSD blaster coil
-3 inch autopower racing harness
-AEM Cam gears (for ls motor)
-Crank pulley (lightweight)
-AEM Underdrive pulleys
-Pillar Gauge pod (have no idea what its for)
-Spoon Sports radiator cap
-Spoon Sports Resevoir covers
-Second Si lower console
-88 CRX Si Seats
-Ls ECU
-Acura Integra meshies
Yet again theres more but i cant remember right now.
Heres the bad:
-Smached Windshield
-Partly primered (can paint white for $500 more dollars)
-timing is off (couple degrees)
Car will run and drive. Got all fluids changed on time. Throwing a code 7 for a TPS thats it. Nothing more, nothing less. Like i said you can take all the Honda **** i have with the car. Take it all! im out of the game. Ok, to the pictures.
Finally, put back together After all this time.
Asking 2000 obo for the car and everything that goes with it. Like i said BEST OFFER! ill sell it for the right price and take everything! i dont need any of it. Let me know ASAP need money......thanks
Modified by civic89si666 at 3:57 PM 9/3/2007
-Custom Test Pipe
-Skunk2 Coilovers
-New Water Pump
-New Timing belt
-New Head Gasket
-New Clutch (oem)
-Ichibahn Pedals
COMES WITH CAR!
-New Axles
-MSD blaster coil
-88 CRX Si Seats
-Ls ECU
Heres the bad:
-Smached Windshield
slammedef06
Sep 2, 2008 05:11 PM
