Pr3 pistons & Rods in gsR ?
Old Sep 3, 2007 | 06:21 AM
HaTa's Avatar
Default Pr3 pistons & Rods in gsR ?
i have a set of pr3 pistons and rods I was going to put in my gsr, but I didnt know if the rods were a difference length and if I should use my gsr rods or those. Also the head was built with low comp valves and I wasnt sure if they were going to make a big impact on doing a mild n/a build. Any help is appreciated thanks.
Old Sep 3, 2007 | 08:09 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Pr3 pistons & Rods in gsR ? (Pass On Left)
what happened when you did a search under "rod lengths"?
Low compression valves? do you mean stock valves? They're fine in any build you'll ever do.
Old Sep 3, 2007 | 08:21 AM
SkankyEJ7's Avatar
Default Re: Pr3 pistons & Rods in gsR ? (00Red_SiR)
just use the pistons, i dont think you like the results with pr3 rods in gsr block
Old Sep 3, 2007 | 08:56 PM
sauceja's Avatar
Default Re: Pr3 pistons & Rods in gsR ? (SkankyEJ7)
Gsr rods and P30 pistons in a GSR block = about 11.5:1 CR
Flat faced valves = .2 - .3 bump in CR
Mill head 0.030 and add another .2 - .3 maybe.
Then get really big cams like buddy club spec IV's
Old Sep 3, 2007 | 09:02 PM
all-mtr-teg's Avatar
Default Re: Pr3 pistons & Rods in gsR ? (sauceja)
what flat faced valves add .2-.3 CR. When i spoke to a rep at Supertech he only told me they bump of CR .08. I calculated my CR off of a .08 bump
Old Sep 3, 2007 | 09:04 PM
sauceja's Avatar
Default Re: Pr3 pistons & Rods in gsR ? (all-mtr-teg)
Everything I have found about the supertech flatfaced valves gave me a .2 - .3 bump.
If its only a .08 then I need to remove a layer off my headgasket.
Old Sep 3, 2007 | 10:11 PM
Chris Tune's Avatar
cc's the head after the installation of the valves... VOILA u got a perfect way to determine compression... at least of impact of the valves on comp.
Old Sep 4, 2007 | 01:43 PM
sauceja's Avatar
Default Re: Pr3 pistons & Rods in gsR ? (Chris Tune)
I had the combustion chambers touched as well so that may lower cc's a little more.
Either way good info.
Old Sep 5, 2007 | 11:44 AM
707CIVIC's Avatar
imma do the pr3 with a gsr built tell me how it comes out and does any one know the highest hp on the same rod piston combo stock bore.
jdmrhdeg
Northeast (Sales)
21
Mar 10, 2010 09:50 AM
type r corey
Nov 19, 2005 02:14 PM
quicksol95
May 2, 2004 01:44 PM
