a few simple questions...
Old Sep 2, 2007 | 09:41 PM
.Grimace's Avatar
footwork mastery
Default a few simple questions...
well here is a breakdown of my super mild build. got a gsr block with no rods or pistons yet and was going to use gsr rods (friend has for free) and was looking at either ctr or itr pistons. (which would you prefer?). the head was just completely gone over 3 angle valve job all new valve train. it has an itr intake manifold and throttle body. trying to decide what cams to use.( want to ditch the stock b16 cams). sounds like the itr's would be a good choice which leads into my next questions...
first off it's a b16 head with a stock valve train would it be a problem to use itr cams with stock b16 springs and retainers?
next question would be, i have gsr rods to use would it be any different to use ctr pistons with this set up instead of itr pistons? using a gsr block btw.
i tried searching but nothing too definete. tyia.
Modified by Gremice at 11:09 PM 9/2/2007
Old Sep 2, 2007 | 10:47 PM
.Grimace's Avatar
footwork mastery
Default Re: a few simple questions... (Gremice)
anyone?
Old Sep 2, 2007 | 11:08 PM
n1_egsex's Avatar
* B A N N E D *
for a mild build, i'd go towards jdm itr p73 pistons
Old Sep 2, 2007 | 11:20 PM
.Grimace's Avatar
footwork mastery
Default Re: a few simple questions... (n1_egsex)
and using itr cams would also go well with that? wouldnt this pretty much be a poor mans itr motor? thank you for input
Old Sep 3, 2007 | 08:17 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gremice &raquo;</TD></TR><TR><TD CLASS="quote">and using itr cams would also go well with that? wouldnt this pretty much be a poor mans itr motor? thank you for input</TD></TR></TABLE>
Of course they would or Honda wouldn't have put them together in the first place. Poor mans ITR? I guess so, what's wrong with that? CTR pistons aren't exactly going to radically change anything.. If you really did search you would have seen huge discussions about using ITR vs CTR pistons...
Old Sep 3, 2007 | 08:35 AM
.Grimace's Avatar
footwork mastery
Default Re: a few simple questions... (00Red_SiR)
i didn't look much into that so much as if using itr cams in a b16 works fine. and from what i gathered the intaje side is fine were as the exhaust side is questionable?
russ.shafer
Mid-Atlantic (Sales)
Mar 14, 2011 09:44 PM
bluejdmdc4
Apr 10, 2009 08:39 PM
DC5ftmfw
11
May 1, 2006 08:05 PM
one8toh8
18
Jun 23, 2005 01:41 PM
91hondacrx
Feb 12, 2003 08:49 PM
