01 accord 4 cyl crankshaft pulley nut - LH or RH?
Old Sep 2, 2007 | 09:23 PM
pdn944's Avatar
Default 01 accord 4 cyl crankshaft pulley nut - LH or RH?
I'm trying to change the timing belt, balance belt, etc, but can't loosen the crankshaft pulley nut. I know it takes a lot of torque to break free, and the dealer says it's a normal right hand thread, but I've tried a 450 ft-lb impact wrench and have doused it with PB Blaster penetrant.
Was I misinformed by the dealer, and this is a left hand thread?
Or do I just need to apply more torque, and/or something else?
Old Sep 4, 2007 | 04:12 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 01 accord 4 cyl crankshaft pulley nut - LH or RH? (pdn944)
it's normal RH thread.
You just need a lot of torque to break it free.
Check out my write-up on how-to replace the timing belt and water pump. A link to it is located in the Accord FAQ sticky up top. I list the parts needed and posted pictures on how I set it up to break it free. I've done it this way a few times and it's worked great every time.
BoaConstrictor
13
Oct 26, 2015 10:09 PM
Pagoda
Mar 7, 2013 08:58 PM
jazyjeff
Jun 21, 2008 06:18 AM
endeavor40ft
May 24, 2007 04:57 AM
stevescivic
Aug 25, 2004 10:14 AM
