No spark, no start, code 15 after d16a6 swap?
Old Sep 2, 2007 | 08:23 PM
norby79's Avatar
Default No spark, no start, code 15 after d16a6 swap?
As says. need help. Checked the grounds already. top of the dizzy warms up when I try to turn it over. Dizzy is getting juice from the ignition. I switch the two white wires and still nothing. any and all help would be appreciated.
the car is a 91 dx hatch with a 89 d16a6 swap.
Modified by norby79 at 7:18 AM 9/3/2007
Old Sep 3, 2007 | 05:07 AM
jlicrx's Avatar
Default Re: No spark, no start, code 15 after d16a6 swap? (norby79)
what car? sounds like that you may have a CRX HF and are trying to use the Si engine harness, which won't work - you need to use the HF engine harness
thecorey
Sep 9, 2008 06:21 PM
norby79
Nov 7, 2007 08:06 PM
pyro_freak8
12
Mar 24, 2004 12:24 PM
pyro_freak8
10
Mar 24, 2004 12:10 PM
