need help with small slicks
Old Jun 14, 2002 | 11:02 PM
integraracer94's Avatar
Default need help with small slicks
I am running 20X6 14's I used these when my car was all motor and now I have the turbo setup and I am having problems. Anyone else running these slicks? Do I have to run tubes in them? I was having a problem spinning valve stems, so I put rim screws in and I am not spinning them anymore but I am still getting flats. When I took them to get them fixed and the guy thought that the tube rubbed over on itself and rubbed a hole.
This never happens when i am making a run, I always notice it on my way back to the pits. Do I have to run the tubes? Any ideas
Old Jun 15, 2002 | 07:39 AM
ExospeedAMcrx's Avatar
Default Re: need help with small slicks (integraracer94)
I'd step up to a bigger slick. the 6"ers are too small for a turbo setup. Step up to a 22x8x13 and that size should last you for awhile.
guarantee you that you'll run better times with a more reliable slick than the 20x6's.
those are good to start with but doesnt hold that great once youre really doing more modifications to your motor.
good luck
Wil
Old Jun 15, 2002 | 06:11 PM
Mista Bone's Avatar
D Tranny Guru
I don't run tubes in my 20x6x14 on steelies or 20x8x14's on 14x6 rims.
Sure the slicks lose air, all rubber tires do! I usually only have to air them up before leaving the house and they are fine for all day at teh track. I usually put in 20 psi when leaving the house, make first pass at 13-14 psi cold, then rest of day at 12-13 psi warm.
Old Jun 18, 2002 | 08:25 PM
FAST94GSR's Avatar
New User
Default Re: need help with small slicks (Mista Bone)
6 inch slicks are like the donuts in your trunk!! LOL. doesn't take much to over power them..
Old Jun 19, 2002 | 05:35 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: need help with small slicks (FAST94GSR)
yeah, but 1.85 60 foots on skinnys sure suprise everyone.
Old Jun 19, 2002 | 06:07 AM
i've even hit 1.75's on the 22x8x14's. but they are so inconsistent on 60 fts below 1.8's its more of a 1.8 60ft kinda tire. like I said before, its easy to overpower these small slicks.
Old Jun 19, 2002 | 06:20 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: need help with small slicks (exospeedAMcrx)
well overpower and SOHC do not fit in the same subject.
808jdm_profileEG6
Jul 31, 2007 08:59 PM
808jdm_profileEG6
Jul 30, 2007 06:17 PM
maxspeedhonda
Jun 8, 2006 02:22 PM
integraracer94
Oct 23, 2002 02:50 AM
92JDMSiR
Apr 18, 2002 06:52 AM
