rpm jumping
Old Sep 2, 2007 | 07:26 PM
civicb16eg's Avatar
Default rpm jumping
finally swapped in the d16y8 but now my rpm is jumping around..it only jumps when im passed 3k rpm..jumps from 3-5 k... any ideas to what it can b?
Old Sep 2, 2007 | 07:30 PM
Syndacate's Avatar
Default Re: rpm jumping (civicb16eg)
When it jumps, does the car jerk too and rev a bit? It sounds like it can be a slipping clutch, but if the car still feels "solid" in acceleration and no sound change, then it probably isn't.
Old Sep 2, 2007 | 07:48 PM
civicb16eg's Avatar
Default Re: rpm jumping (Syndacate)
it sounds solid...its a new clutch...can that b the problem?
Old Sep 2, 2007 | 08:02 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg &raquo;</TD></TR><TR><TD CLASS="quote">it sounds solid...its a new clutch...can that b the problem?</TD></TR></TABLE>
Well if it's a new clutch it's still breaking in...if you were hard on it there's a good chance you could have fucked it up - you have to go easy on it for the break-in period (1000 miles)?
Old Sep 2, 2007 | 08:16 PM
civicb16eg's Avatar
no i didnt go hard on it...i know i have to break it in but will the new clutch cause the rpm to surge?
Old Sep 2, 2007 | 09:06 PM
Rad!'s Avatar
do you have msd?
Old Sep 2, 2007 | 09:18 PM
jmankush's Avatar
* B A N N E D *
im havin the same thing happend but i got a 1.5 v-tech just put it in and the rpms r jumping at 25 to 38 don't know why someone said it could be the feul filter have you changed it or cleaned it?
Old Sep 2, 2007 | 10:11 PM
civicb16eg's Avatar
Default Re: rpm jumping (Rad!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rad! &raquo;</TD></TR><TR><TD CLASS="quote">do you have msd?</TD></TR></TABLE>
no MSD
Old Sep 2, 2007 | 10:12 PM
civicb16eg's Avatar
Default Re: (jmankush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmankush &raquo;</TD></TR><TR><TD CLASS="quote">im havin the same thing happend but i got a 1.5 v-tech just put it in and the rpms r jumping at 25 to 38 don't know why someone said it could be the feul filter have you changed it or cleaned it? </TD></TR></TABLE>
Rpm was working fine with the b16 so i dont think it can be the fuel filter
Old Sep 2, 2007 | 10:14 PM
cartune network's Avatar
i cant imagine the rpms bouncing like that when ur in gear. if its doing it in gear that it would be just luck your puttin your foot down on the pedal. and if u say its not jerking than its not doing it in gear. my question is can u actually hear the motor revving up or no? cause if u cant then its just ur gauge lol my accord did that for a while and then just went away.
Old Sep 2, 2007 | 10:56 PM
civicb16eg's Avatar
Default Re: rpm jumping (cartune network)
motors not revving... gauges worked fine before.. when im revving the engine out of gear the rpm would be perfectly fine..its just when im in gear the rpm starts to bounce..
Old Sep 3, 2007 | 10:07 AM
civicb16eg's Avatar
bump for some help
Old Sep 5, 2007 | 12:07 AM
jmankush's Avatar
* B A N N E D *
yah man im havin the same porb. so when u find out wut it is let me know too. but wit mine after a while it just gose away and the car runs fine its only when thecar has been off for a day or two . it starts to get annoying after a while the car is jerking back and forth. hope you find out wut it is for both of us cause i want to know how to fix it aready. thx good luck
chickenwing
Sep 17, 2008 02:41 AM
j_rohlfing
Feb 3, 2007 01:09 PM
TEGGRY
Mar 24, 2006 04:21 AM
projectej8
26
Jul 3, 2004 09:31 AM
kseriesDC5
Mar 24, 2004 08:11 AM
