Camber kit?
Old Sep 2, 2007 | 09:31 AM
BJA86's Avatar
Default Camber kit?
i went to get an alignment and they told me they couldnt align it because my car is lowered on springs it requires a camber kit.
is this true? if so
how hard is it to install a camber kit and and what are some kits you guys have had experience with?
Old Sep 2, 2007 | 09:33 AM
97Ej6mike's Avatar
You dont need one, tell them you want 0 degree's of toe, dont worry about the camber.
Old Sep 2, 2007 | 09:41 AM
BJA86's Avatar
Default Re: (97Ej6mike)
what does 0 degrees of toe mean exactly?
Old Sep 2, 2007 | 09:47 AM
97Ej6mike's Avatar
0 degrees of toe basically means that both wheels will be aligned as such to both be stright forwrd, neglecting camber, which is the inward or outward tilt of a wheel.
As a car is lowered (modified), it naturally gets positive ( i think?) camber, or to state it simply, an inward tilt. Im not a pro on camber, but this is caused by how the control arm is now sitting at a different angle from how it was designed to sit, at stock height.
Old Sep 2, 2007 | 10:12 AM
BadA$$Si's Avatar
just buy yaself front and rear camber kit and then get your car aligned and its simple to install a camber kit
Old Sep 2, 2007 | 10:40 AM
GYChris's Avatar
Default Re: Camber kit? (BJA86)
when you lower your car, the result is negative camber (which is the top of your tire leaning towards the inside of your car.) negative camber causes uneven tread wear on your tires (on the inside shoulder)
to get correct tire wear, and close to manufactured specs on the alignment, yes you do need a camber kit if your vehicle is lowered. but that is only if you care about your tires.
if you dont mind your tires wearing quickly on the inside shoulder, then just tell them to set the toe and let it go. (toes is basically which way the front of your tire is pointing) otherwise, just purchase the camber kit for the front and rear and then have them adjust it. they are not hard to put in
(im an alignment technician, so i know a little here and there )
Old Sep 2, 2007 | 10:41 AM
ke98248's Avatar
Default Re: Camber kit? (slowEGchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEGchris &raquo;</TD></TR><TR><TD CLASS="quote">when you lower your car, the result is negative camber (which is the top of your tire leaning towards the inside of your car.) negative camber causes uneven tread wear on your tires (on the inside shoulder)
(im an alignment technician, so i know a little here and there )</TD></TR></TABLE>
Old Sep 2, 2007 | 10:42 AM
ke98248's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">0 degrees of toe basically means that both wheels will be aligned as such to both be stright forwrd, neglecting camber, which is the inward or outward tilt of a wheel.
As a car is lowered (modified), it naturally gets positive ( i think?) camber, or to state it simply, an inward tilt. Im not a pro on camber, but this is caused by how the control arm is now sitting at a different angle from how it was designed to sit, at stock height. </TD></TR></TABLE>BS
Old Sep 2, 2007 | 10:57 AM
GYChris's Avatar
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">BS </TD></TR></TABLE>
the only thing he was wrong on was the positive camber part, he was on the right track though
Old Sep 2, 2007 | 11:05 AM
BJA86's Avatar
Default Re:
awesome thanks for the info guys
Old Sep 2, 2007 | 11:57 AM
bmoua's Avatar
all you need is a front camber kit pref. skunk2, omni, blox....for the rears just do the washer trick. There is no use to getting a rear camber kit.
Old Sep 2, 2007 | 01:00 PM
GYChris's Avatar
Default Re: Camber kit? (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
for the rears just do the washer trick. There is no use to getting a rear camber kit. </TD></TR></TABLE>
yes, i agree
hatch_
Feb 10, 2009 09:25 PM
khronicboy420
Dec 23, 2008 11:12 AM
dom93hatch
Apr 19, 2003 10:26 PM
631 Teggy
Jan 18, 2003 07:38 AM
Anderson
Jun 18, 2002 01:06 PM
