what to use to seal bondo
Old Sep 2, 2007 | 08:26 AM
banginek96's Avatar
Default what to use to seal bondo
i painted my ek championship white about a month ago and after we were finished we noticed that the doors were yellow where we bondo'd but we only used spray primer. Is there a certain sealer that u can use so that the bondo doesnt react with the paint and come through? Someone get back to me asap.
Old Sep 2, 2007 | 01:40 PM
b20powereDA's Avatar
Default Re: what to use to seal bondo (banginek96)
so u primed over the bondo? i would recommend sealing the panel that u are painting. if u are intending on painting the whole car, i would recommend sealing the whole car
Old Sep 4, 2007 | 06:45 PM
exvelocity's Avatar
well if you already painted the car,assuming you used catalyst with the paint or the clear, you can just scuff and re-shoot the panels with the spots, but in the future, you need to apply 2k primer or some polyester primer with MEKP hardener, stay away from rattle can garbage!
Old Sep 5, 2007 | 07:03 PM
powerflow's Avatar
Default Re: what to use to seal bondo (exvelocity)
^^^Yep, rattle can primer is ok in some situations but for real work its poop in a can. The filler went right through it and bled into the base. I've wiped that **** off with wax/ degreaser, some of it is that weak. 2k high build, and you can base right over that.
Old Sep 5, 2007 | 07:30 PM
exvelocity's Avatar
Yep,unless he spends $15 a can of U-Pol,SEM or 3M,most that parts store garbage will wipe right off with prep-solv
raverx3m
Paint and Body
Jun 3, 2015 07:55 PM
Charlie Moua
Paint and Body
Jul 23, 2014 05:13 AM
builthatch
Paint and Body
13
May 29, 2009 11:11 PM
00trdtaco
Paint and Body
Dec 15, 2008 01:47 PM
zseeanz
11
Dec 13, 2002 08:59 PM
