k20 swap? ups... downs?
Old Sep 2, 2007 | 12:30 AM
wagner0807's Avatar
Default k20 swap? ups... downs?
i'm thinkin bout swapping a k20 from a 2002 rsx type s to my crx. i already know i need motor mounts and shift linkage what else might i need? what are some ups and downs to the k20 swap to a crx? help is appreciated.
Old Sep 2, 2007 | 12:42 AM
90sedan's Avatar
Default Re: k20 swap? ups... downs? (wagner0807)
Here's a great link, i've used it many of times and 9/10 times i find the answer i'm looking for in a matter of minutes.
https://honda-tech.com/zerosearch
Old Sep 2, 2007 | 05:44 AM
CRX Toad's Avatar
Please check the FAQ also.
Old Sep 2, 2007 | 07:02 AM
Red_ED8's Avatar
You might want to check on k20.org if you can't find everything on H-T but you will need:
k-pro ecu (or AEM)
hasport mounts (not sure if anyone make mounts for ef besides from hasport) custom axels (hasport)
sub harness conversion (hasport, rywire)
shifter box (karcept)
intake (almost any short ram intake for RSX)
Just to name a few of the things you need. The up's, the K responds well to bolt ons, flows better then a B, not as heavy as an H. The downs, expensive, expensive, expensive. But all this info can be found if you "Search" it.
Old Sep 2, 2007 | 07:38 AM
gator88's Avatar
Default Re: k20 swap? ups... downs? (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">You might want to check on k20.org if you can't find everything on H-T but you will need:
k-pro ecu (or AEM)
Just to name a few of the things you need. The up's, the K responds well to bolt ons, flows better then a B, not as heavy as an H. The downs, expensive, expensive, expensive. But all this info can be found if you "Search" it.</TD></TR></TABLE>
/thread. that says it all right there, unless bart comes back around and offers some of his info
sleepercrxk24
K Series
27
Apr 2, 2014 02:11 AM
EGeek
Honda Civic (2001 - 2005)
Feb 22, 2014 07:23 PM
bsivoljr
May 1, 2009 03:51 PM
frankboy1269
Oct 30, 2006 08:51 PM
kcjohnnyboy
Feb 23, 2006 10:50 PM
