H22 vs B18C5
Old Sep 1, 2007 | 10:44 PM
disrupter006's Avatar
Default H22 vs B18C5
When considering the weight, numbers, and prices...
H22=faster, cheaper, easier to install?
From what I've read, that seems to be the case, will someone correct me if I'm wrong?
Old Sep 1, 2007 | 10:48 PM
smileycvc's Avatar
Default Re: H22 vs B18C5 (disrupter006)
The H2B is better than the C5, but just an h22 or a c5. I would go with the c5 if you can get it for a good price. Without the H2B conversion you might have problems with axle alignment and the way the motor sits. There are clean h22 swaps out there though. Just make sure you do alot of research before you go either way. Personal I would never buy a c5 because they are overpriced, but if those are your only choices then there you go.
Old Sep 1, 2007 | 10:52 PM
Default Re: H22 vs B18C5 (smileycvc)
My choices are endless...well I want to keep this under 4000 for the complete swap (not including labor).
I want the best bang for that buck...I really don't know where to go. My knowledge, though expanding, is not THAT vast yet. H22A looks nice, and has a good price tag on it...but why is it not a good choice?
Old Sep 1, 2007 | 11:28 PM
sol2hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disrupter006 &raquo;</TD></TR><TR><TD CLASS="quote">When considering the weight, numbers, and prices...
From what I've read, that seems to be the case, will someone correct me if I'm wrong?</TD></TR></TABLE>
your wrong. lol
at the top of the forum you will find this---&gt; https://honda-tech.com/zerothread/878010
in that, you will find a list of possible swaps, and their pros and cons, thats a good place to start.
If you do a h22, then look into doing whats called an H2B conversion. Its basically a h22 mated via adaptor plate to a b series tranny. More info on that here---&gt; https://honda-tech.com/zerothread/1998426 and here---&gt; https://honda-tech.com/zerothread/1638988. both those are in the Hybrid forum, also a good place for you to start looking.
Hope that helps.
Old Sep 2, 2007 | 08:29 AM
Tyte-S's Avatar
Default Re: H22 vs B18C5 (sol2hatch)
If your choices are endless, have you considered a k series swap?
Old Sep 2, 2007 | 08:33 AM
97Ej6mike's Avatar
Default Re: H22 vs B18C5 (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">If your choices are endless, have you considered a k series swap?</TD></TR></TABLE>
K-series swaps are sweet, but are very pricey for any 92-00 civic, and time consuming. If you have the time & money, then by all means go for it, but do all your research first, theres quite a bit that goes into swapping a K series to any EG/EJ/EK chassis. For a K swap, when all is said and done, your looking at around 5~7 K spent on parts and labor.
Old Sep 2, 2007 | 08:59 AM
doubleshotz's Avatar
turbo D=best bang for buck
Old Sep 2, 2007 | 09:05 AM
95ProjectEJ1's Avatar
Default Re: (doubleshotz)
I would rather have a turbo B18b1...
Old Sep 2, 2007 | 09:10 AM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleshotz &raquo;</TD></TR><TR><TD CLASS="quote">turbo D=best bang for buck</TD></TR></TABLE>
You might be lucky to make 250 whp on a ~$2000 setup and run 13's.
The same priced h2b will run the same with a stock motor with way more potential.
Sure it's a good bang for the buck, but most people are turboing motors with 130k+ on them.
A b18c5 will be overpriced, but you can certainly get a light car into the 13's with one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I would rather have a turbo B18b1... </TD></TR></TABLE>
Of course you would
h2b
Modified by ek forever guy at 7:08 AM 9/3/2007
Modified by ek forever guy at 7:16 AM 9/3/2007
Old Sep 2, 2007 | 09:12 AM
Bense's Avatar
time vs money
more money than time, b18c5
more time than money, h22
b-series trans &gt; h-series trans.
Old Sep 2, 2007 | 09:42 AM
EKris's Avatar
Default Re: H22 vs B18C5 (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">time vs money
b-series trans &gt; h-series trans.</TD></TR></TABLE>
Old Sep 2, 2007 | 10:17 AM
wht92lude's Avatar
whats so bad about the h22 tranny? is it just that nobody like the feel of the cables? it doesnt feel that bad i had an h22 in my prelude and it felt really good? always wondered why everybody dislikes the h22 tranny? or is it a gearing reason i thought the gears were kinda short. 3100 rpm at 60, is that short or just me...?
Old Sep 2, 2007 | 10:27 AM
H22poweredEJ8's Avatar
deinatly i would go with the h2b. but the h-tranny isnt that bad. i like it. just throw a type s 5th gear in it for cruising on the highway, unless you dont go highway alot
Old Sep 2, 2007 | 11:00 AM
Ekb18c5_BR's Avatar
Default Re: (H22poweredEJ8)
b18c5
Old Sep 2, 2007 | 11:03 AM
oneoffaccord's Avatar
Default Re: (Ekb18c5_BR)
H22 FTW. best bang for the buck. its a endless conversation. the torque of the h22 wins me over
Old Sep 2, 2007 | 11:30 AM
Bense's Avatar
Default Re: H22 vs B18C5 (wht92lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht92lude &raquo;</TD></TR><TR><TD CLASS="quote">whats so bad about the h22 tranny?</TD></TR></TABLE>
straight h22 swap requires
custom mounts
custom axles
Nothing the frame for the pass side mount
cutting the shift tunnel for the cable shifter
cable shifters suck and you can't feel what you're doing
aftermarket support for the h22 trans is crappy
h22 trans weighs more
h22 trans doesn't have nearly the amount of aftermarket support as b-series
shortest F/H trans is the euro R, which is insanely impossible to find.
Axle geometry of H22 trans in a civic sucks, expect to break lots of axles.
H22 trans is geared like a GSR trans with an LS final drive.
GSR gearing is better than h22 trans
B16/ITR gearing is better than GSR trans.
Old Sep 2, 2007 | 11:43 AM
Syndacate's Avatar
custom mounts
custom axles
Pretty much sums it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht92lude &raquo;</TD></TR><TR><TD CLASS="quote">whats so bad about the h22 tranny? is it just that nobody like the feel of the cables? it doesnt feel that bad i had an h22 in my prelude and it felt really good? always wondered why everybody dislikes the h22 tranny? or is it a gearing reason i thought the gears were kinda short. 3100 rpm at 60, is that short or just me...?</TD></TR></TABLE>
Well people bitch about the cables but that's not really the bad part - the bad part is the their length - it has tall gears.
If you go with an H2B you can reuse the trans and rear mount (only need an H22 to EG/EK driverside mount), run B series axles (which out-live H series axles for some reason), your transmission will be more durable, and you'll have faster acceleration.
An H2B w/ a B16 will run pretty damn close to an ITR - if not beat it - depending on the condition of the engine.
H2B &gt; ITR any day.
ITR &gt; standard H22.
Old Sep 2, 2007 | 11:48 AM
Bense's Avatar
Default Re: H22 vs B18C5 (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">(only need an H22 to EG/EK driverside mount)</TD></TR></TABLE>
H2B uses a STOCK b-series driver side mount that connects to the custom timing belt mount that comes with the QSD & Evolution kit.
However it is reccomended to use Energy suspension inserts at the minimum. I opted to get a hasport stock dc2 replacement
Funny, hasport uses the stock dc2 mount to connect to the custom bracket for the k-series trans. I guess you could say that the h2b/eg/dc2 uses a kseries driverside mount.
Old Sep 2, 2007 | 12:15 PM
Syndacate's Avatar
Ah, I C, didn't know that came with the H2B kit.
Old Sep 2, 2007 | 12:53 PM
TeamRiskEG6's Avatar
jdm h
i recently swapped my usdm h with a jdm h in my eg... bone stock untuned took to the track and ran a 13.2.. with a 1.7 60ft...attarco motor. not bad
http://youtube.com/watch?v=BInAEF1kOfA
Old Sep 2, 2007 | 12:58 PM
Default Re: H22 vs B18C5 (TeamRiskEG6)
and i will add the one down side to having a h motor.. used parts are harder to come by than a b series motor...
Old Sep 2, 2007 | 02:38 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRiskEG6 &raquo;</TD></TR><TR><TD CLASS="quote">and i will add the one down side to having a h motor.. used parts are harder to come by than a b series motor... </TD></TR></TABLE>
And info is harder to get.
Though they're both available if you look.
Old Sep 2, 2007 | 02:51 PM
So is there any all together Kit i can get for a "H2B?" Or will I have to purchase the H22 complete swap and then go buy a B tranny?
Old Sep 2, 2007 | 02:58 PM
It looks like H2b is going to run like 5 grand just on parts...am I thinking correctly?
Hmotors:
H22A 92-95 Long Block
Price: $ 1200.00 Plus shipping and handling.
Availability: In Stock
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- P13 ECU (Add $200)
I would need this, the kit, and the B series equipment?
Old Sep 2, 2007 | 03:06 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disrupter006 &raquo;</TD></TR><TR><TD CLASS="quote">It looks like H2b is going to run like 5 grand just on parts...am I thinking correctly?</TD></TR></TABLE>
Maybe, depends.
You can buy an H22 long block for 1.2k from hmotors with a 100% startup warranty
You can get a long block minus a transmission locally for maybe 500-1k.
So you do that, maybe 6-800 for a B series transmission, another ~800 for the H2B kit, so that's around 3 grand tops..then ya gotta wrap it up - B series mounts, axles, linkage (common enough) and an H22 ECU or an OBD-I chipped ECU w/ an H22 basemap.
So no, it shouldn't cost 5 grand in parts - maybe 3-3.5 if you shop around for a bit and know what a good deal is opposed to getting raped.
