will this intake fit? --n00b
Old Sep 1, 2007 | 10:28 PM
tpot90's Avatar
Default will this intake fit? --n00b
I have had this intake for a while, but would it work on my Accord? Also, is this considered a SRI? I would get a K&N filter with it..Will I need any other tubes or anything like that?
Thanks
Old Sep 1, 2007 | 11:09 PM
2fast4urass's Avatar
Default Re: will this intake fit? --n00b (tpot90)
if u have a v-tech this all u will need, unless u want a cold air intake
Old Sep 1, 2007 | 11:11 PM
SuShiBoiiii's Avatar
from the looks of it no
Old Sep 1, 2007 | 11:17 PM
tpot90's Avatar
Default Re: will this intake fit? --n00b (SuShiBoiiii)
Awesome. Thanks guys. I'm ganna check it out in the morning. My car will already have the breather hose that goes on the stock junk, correct?
Ima post pix if this works out. Appreciate it, d00dz.
Old Sep 1, 2007 | 11:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 &raquo;</TD></TR><TR><TD CLASS="quote">will already have the breather hose that goes on the stock junk,
yup
Old Sep 2, 2007 | 06:30 AM
awdgsx96's Avatar
Yes, that would be a SRI
Old Sep 2, 2007 | 09:11 AM
hurleyint's Avatar
Default Re: will this intake fit? --n00b (awdgsx96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4urass &raquo;</TD></TR><TR><TD CLASS="quote">if u have a v-tech this all u will need, unless u want a cold air intake</TD></TR></TABLE>
wtf
Old Sep 2, 2007 | 10:22 AM
tpot90's Avatar
Well it turns out that it doesnt fit right off the bat. The intake starts out straight and then has a bend in it. Honda intakes all have an immediate bend to them. The filter of my aftermarket intake ends up in the ECU box.
Any suggestions or sollutions?
Old Sep 2, 2007 | 10:31 AM
awdgsx96's Avatar
You'd just have to cut or heat and bend to shape. I don't know what kind of material it is, and if it is malleable at all.
Just curious, did you get it for free? Or did you order an intake for another vehicle accidentally instead of for your Accord?
Old Sep 2, 2007 | 10:37 AM
tpot90's Avatar
I didn't buy it. My brother bought it for his gf's car but it didnt fit so he just handed it over to me years ago before i even had a car. I want to make use of it now.
Old Sep 2, 2007 | 10:53 AM
awdgsx96's Avatar
Eh, if you get it for free, experiment with some cuts or bends. In the end if didn't work, you got it for free who cares. If it works, you got a free SRI.
Old Sep 2, 2007 | 11:09 AM
g0getta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">from the looks of it no </TD></TR></TABLE>
x2
That looks more like a integ or civic intake.
The one on my accord is longer and reaches all the way down to my head light. So since that one only goes to your fuse box then its the WRONG one.
Old Sep 2, 2007 | 11:47 AM
kleen98accord's Avatar
try and install it the other way. where the breather nipple is, that should be the side that attaches to the throttle body. and the filter should just go on the other end.
Old Sep 2, 2007 | 01:45 PM
Hammer99ex's Avatar
Default Re: will this intake fit? --n00b (kleen98accord)
this is what i was thinking too...
it might not work tho... may be too close to the dizzy
you could cut about 3 inches off the straight end, might work then
Old Sep 2, 2007 | 06:27 PM
HondaAccordTdR's Avatar
Default Re: will this intake fit? --n00b (Hammer99ex)
I agree, work with it yourself to see if you can make it fit. If not... no worries you can pick them up for cheap.
Old Sep 2, 2007 | 07:16 PM
gianinline's Avatar
Default Re: will this intake fit? --n00b (2fast4urass)
nothing else needed.... just from that intake... your "v-tech" will kick in a lot harder and earlier... might need to upgrade ECU!!
Old Sep 2, 2007 | 10:36 PM
tpot90's Avatar
Default Re: will this intake fit? --n00b (gianinline)
youre a genius! I never thought of switching the sides. I was taking off the filter to switch em around when it broke. Its a crappy little filter; I'm ganna test out the new fit tomorrow & if it works out, im ganna go get a K&N filter.
Except, what kind of K&N do i get? This is a generic pipe, aren't K&N filters fitted for certain models?
Old Sep 4, 2007 | 11:07 AM
Hammer99ex's Avatar
k&n part number RR 3003 its a reverse conical filter 3" opening
http://knfilters.com/search/pr...-3003
Old Sep 4, 2007 | 11:19 AM
JDM_CD7's Avatar
Thats a intake for a Civic.
Will work, but will look like ***.
low430
Oct 30, 2005 08:10 PM
rasta420
Acura TL, RL & ZDX
Sep 20, 2005 01:47 AM
lastpunkinline
May 22, 2005 08:50 AM
the_0ne
25
Aug 10, 2004 02:29 AM
Tommy_Gunns
Jul 23, 2001 01:23 PM
