best drop on ek??
Old Sep 1, 2007 | 10:28 PM
kasperxtcy's Avatar
Default best drop on ek??
well i just got a new ek and i was wondering what you guys think is the best drop for an ek? On my last ek i dropped it on H&R sport springs and kyb gr2. not the biggest drop i know but i want something different. so give me some input.
Old Sep 1, 2007 | 11:10 PM
5lug2000's Avatar
Default Re: best drop on ek?? (kasperxtcy)
ground controls+koni yellows
Old Sep 1, 2007 | 11:12 PM
RARE_EG2's Avatar
Default Re: best drop on ek?? (5lug2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5lug2000 &raquo;</TD></TR><TR><TD CLASS="quote">ground controls+koni yellows </TD></TR></TABLE>
and you can choose your own right height
Old Sep 1, 2007 | 11:56 PM
jdm_ekcivic's Avatar
TEIN SS.
Old Sep 2, 2007 | 12:44 AM
EM1ly's Avatar
function&form
Old Sep 2, 2007 | 12:45 AM
Eran's Avatar
HT White Ops
GC's + Koni Yellows or Tokico Illuminas.
Old Sep 2, 2007 | 05:39 AM
B00STNH22EK's Avatar
TEINS!!!!!!!! I don't know how much you want to spend...but I got the Flex coilover system with EDFC...I can't even explain to you how awesome the ride is...
Old Sep 2, 2007 | 06:20 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: best drop on ek?? (B00STNH22EK)
There's no "perfect height"
There's a "right" height for each driver.
I personally enjoy H&R race on a good shock like Koni yellows or Illuminas.
Koni + Ground control
Tokico + ground control
Or either of those shocks with a good progressive spring like H&R, eibach, or neuspeed.
Old Sep 2, 2007 | 08:54 AM
kasperxtcy's Avatar
Default Re: best drop on ek?? (ek forever guy)
well with a 2 inch drop you guys think i would need a camber kit? i have searched and a lot of pple said just to do an alignment and zero the toe.
Old Sep 2, 2007 | 08:58 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasperxtcy &raquo;</TD></TR><TR><TD CLASS="quote">well with a 2 inch drop you guys think i would need a camber kit? i have searched and a lot of pple said just to do an alignment and zero the toe. </TD></TR></TABLE>
If you want add a few washers to the upper arm bolts in the rear. You want some positive camber for handling purposes. But with zeroed toed you'll be fine on tire wear.
Old Sep 2, 2007 | 09:27 AM
kasperxtcy's Avatar
will i feel a difference with the washers? i mean i am not trying to do any racing or tracking. anything i just want a better ride then i had before.
Old Sep 2, 2007 | 10:04 AM
BEE1's Avatar
Ground Control & Yellow Koni's. Tried and true setup with lifetime warranty.
Old Sep 2, 2007 | 10:13 AM
BadA$$Si's Avatar
word...
Old Sep 2, 2007 | 10:21 AM
NOFX's Avatar
H-T White Ops
It doesn't matter how much you lower it. There will still be some assbag who tells you it should be lower.
Start looking at cars in the A/C section and when you find something you like the look of, PM the owner/poster and see if they might be able to tell you the setup. After that, research that setup and any other setup you've found to like the look of. Then hopefully you can find something you like the looks and performance of.
kevinm1981
Mar 29, 2010 11:02 PM
jdmrida
Suspension & Brakes
Feb 18, 2009 08:20 PM
ek9tl
12
May 22, 2006 07:44 PM
PnkRokCountryboy
Jul 11, 2005 09:22 AM
