Strut removal
I’m new to the Honda forum and did a little searching with no luck so here it goes .I’m working on a 1995 Honda accord 4 door V6.Im trying to replace the rear struts the lower bolt holding the strut is a problem. It was hard to get loose but I freed it with a impact wrench but apparently there is a rubber bushing mess keeping the bolt from coming out to free the strut. What’s the procedure in removing and replacing it? Thanks in advance.A DIY on this?
is the bolt seized in the bushing? i had this same problem and had to cut the strut and then burn the bushing out and replace it. more info will help, maybe some pics of what you are having trouble with.
komat
20
Dec 26, 2004 10:04 PM
