car turns off when i try to adjust idle speed.
Old Sep 1, 2007 | 08:02 PM
deeznuts6009's Avatar
Default car turns off when i try to adjust idle speed.(got code 14)
hey,,, i have a 97' teg. B18B. i got the valve lash adjustment and after i had a crazy idle. i tried to adjust the idle speed, and when i uncliped the connecter from the IAC my teg just turned off. i tried it twice. now i have a crazy idle and it feels like it wants to turn off. mostly when im at a stand still. latter i my engine light came up,, it was code 14- Electronic Air Control. any ideas.. thanks
Old Sep 1, 2007 | 10:10 PM
BLKGSR24's Avatar
Default Re: car turns off when i try to adjust idle speed.(got code 14) (deeznuts6009)
Helms says after disconnecting IAC valve, to start the engine with the accelerator pedal slightly depressed. Stabilize the rpm at 1,000 then slowly release the pedal until the engine idles. With no load and IAC disconnected, idle speed should be 480 plus/minus 50 RPM. Hope that helps some
Modified by BLKGSR24 at 12:35 AM 9/2/2007
Old Sep 1, 2007 | 10:23 PM
Berlinetta F1's Avatar
did you resette your ECU after the valve adjustment?
Old Sep 2, 2007 | 08:04 AM
Default Re: car turns off when i try to adjust idle speed.(got code 14) (BLKGSR24)
i tried i think i let go of the gas too quick im gonna try it againe thanks
Old Sep 2, 2007 | 08:24 AM
Default Re: car turns off when i try to adjust idle speed.(got code 14) (Berlinetta F1)
yes i reset the ECU. twice and the second time seemed to work but well it didnt.
Old Sep 2, 2007 | 04:06 PM
blkgsr24 it didnt seem to work. i dont know... im going to read up on it around the internet... thanks though.
Old Sep 6, 2007 | 04:38 PM
blkGSR24. okay i have tired the idle thing. just cant get it to work i must be doing something wrong or i think i need to take it in whitch i dont want to do. i got it to idle okay but still studers. i have tried about everyday since the last post looks like im useing more gas now. but ill keep trying. any tips..
Old Sep 6, 2007 | 04:42 PM
Dogginator's Avatar
Daisy... Daisy...
Have you checked the ignition timing before trying to set the idle? Turn the idle adjustment screw CCW a few turns to allow more air into the engine. This should help it idle. The car is also supposed to be warm with all lights and accessories turned off.
Old Sep 6, 2007 | 05:01 PM
Default Re: car turns off when i try to adjust idle speed.(got code 14) (Dogginator)
yes i tried that. i had to let more air in just to get it to run better. i let the car warm up to opp. temp.
blasph3my1
Feb 28, 2013 07:46 PM
troyport
Classic Hondas
May 28, 2009 09:06 AM
v1crattlehead
May 30, 2008 07:08 PM
street_ride14
May 5, 2007 10:13 PM
phill
Sep 9, 2004 08:01 AM
