How does the stick shift angle?
Old Sep 1, 2007 | 06:00 PM
ITRex's Avatar
Default How does the CRX stick shift angle?
I checked out a CRX today and the shift stick angle kind of weird. Instead of it angle back at the rear, it was forward. Is this normal? Also I think it have a short shifter.
Car is a 1988 CRX.
Modified by ITRex at 7:14 PM 9/1/2007
Old Sep 1, 2007 | 06:23 PM
almost_stock_civic's Avatar
Default Re: How does the CRX stick shift angle? (ITRex)
if its like my civic, the angle should point to the back of the car. someone probably unbolted the shifter from the shift rod underneath and spun the shifter around.
Old Sep 1, 2007 | 06:44 PM
Crx Jimmy's Avatar
Default Re: How does the CRX stick shift angle? (almost_stock_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almost_stock_civic &raquo;</TD></TR><TR><TD CLASS="quote">if its like my civic, the angle should point to the back of the car. someone probably unbolted the shifter from the shift rod underneath and spun the shifter around. </TD></TR></TABLE>
Um no, If you have ever taken a stock shifter out it is the same both ways. it is straight.
To the OP does the car have a swap, if so the linkage might be home made and the stick sits weird because they made the linkage too long.
And the obvious question is, was it in 1st 3rd or 5th gear? if so, yes it will be forward
Old Sep 1, 2007 | 06:53 PM
ITRex's Avatar
Default Re: How does the CRX stick shift angle? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">To the OP does the car have a swap, if so the linkage might be home made and the stick sits weird because they made the linkage too long.
And the obvious question is, was it in 1st 3rd or 5th gear? if so, yes it will be forward </TD></TR></TABLE>
The shifter was in neutral. Car is basically stock.
Old Sep 1, 2007 | 07:12 PM
fireant's Avatar
I'm no doctor House, but I'd be looking at the fore and aft trans mounts, and also shifter mounts and bushings... but who knows, maybe its an aftermarket installed backwards.
Old Sep 1, 2007 | 07:13 PM
ITRex's Avatar
Default Re: How does the CRX stick shift angle? (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">I'm no doctor House, but I'd be looking at the fore and aft trans mounts, and also shifter mounts and bushings... but who knows, maybe its an aftermarket installed backwards.</TD></TR></TABLE>
Yeah, I was hoping that someone installed it backward.
Old Sep 1, 2007 | 08:21 PM
abram_quito's Avatar
a short shifter only accomplishes
faster shifting and faster response
that's it
i have one
i shift faster and response faster
no hp or torque gained
Old Sep 1, 2007 | 08:35 PM
89Turbo_Angel's Avatar
Default Re: (abram_quito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">a short shifter only accomplishes
that's it
i have one
no hp or torque gained</TD></TR></TABLE>
Ok?
Old Sep 1, 2007 | 09:08 PM
Crx Jimmy's Avatar
that's it
i have one
WTF is up with this guy?
Look, read what he just posted in another thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">CAI does not make a difference in HP
it only accomplishes noise
without the resonator to quiet the suction
with the CAI
you can hear the suction at all times</TD></TR></TABLE>
WTF??
This was on another thread (or maybe I just made it up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito's_mom &raquo;</TD></TR><TR><TD CLASS="quote"> sorry my son is a such a douche </TD></TR></TABLE>
Old Sep 1, 2007 | 09:15 PM
denraweb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRex &raquo;</TD></TR><TR><TD CLASS="quote">I checked out a CRX today and the shift stick angle kind of weird. Instead of it angle back at the rear, it was forward. Is this normal? Also I think it have a short shifter.
Car is a 1988 CRX.
Modified by ITRex at 7:14 PM 9/1/2007</TD></TR></TABLE>
Lol mine is the same way. I have short shifter (single bend) with a b16 swap with custom hasport linkage (which is too short). I installed the shifter backwards after I had to redo the linkage 'cuz the tow truck driver let it drag for 13 miles...
Old Sep 2, 2007 | 01:07 PM
imgoingforit's Avatar
Default Re: How does the CRX stick shift angle? (denraweb)
I think abram quito got banned from crxcommunity.
-Chris
Old Sep 2, 2007 | 02:19 PM
cars101's Avatar
my buddies was like this in his hatch. The gearbox in the tranny was messed. I dont know if thats your problem
Old Sep 2, 2007 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Um no, If you have ever taken a stock shifter out it is the same both ways. it is straight. </TD></TR></TABLE>
apparently, crx and hatch shifters are different, because mine is stock and angles to the back(the section that is in the car anyways). i have a dx with the 5 speed. my bad for trying to help.
Hatchman98
Mar 20, 2007 10:51 AM
dr_latino999
22
Jan 15, 2007 04:14 AM
ru2slo
Apr 5, 2004 08:45 PM
jdmjay04
15
Mar 19, 2004 02:40 PM
HatchBox
10
Jun 11, 2002 05:53 PM
