brake hose replacement please help
Old Sep 1, 2007 | 04:44 PM
billyinse's Avatar
Default brake hose replacement please help one more ?...
so the screws that hold up my brake hose bracket snapped and my brake line got rubbed throught from the tire but anyway i took off the wheel and where the hose meets the hard pipe theres what appears to be a clamp of sorts is there any special tool i need to take these off or put them on or what please help
Modified by billyinse at 12:54 PM 9/5/2007
Old Sep 1, 2007 | 05:03 PM
SKDRCR's Avatar
Default Re: brake hose replacement please help (billyinse)
where the rubber part of the meets the metal part isnt where you disconnect it, follow the hard part of the line down to the caliper, there should be 1 bolt
holding it in with a washer on each side of it.
Disconeect it there.
Old Sep 1, 2007 | 05:04 PM
prelude_h22vtec's Avatar
the part that holds it the hard line is just a clip, you can pry it off with a screwdriver or w/e, but loosen it before you pull the clip off
Old Sep 4, 2007 | 04:42 PM
billyinse's Avatar
Default Re: (prelude_h22vtec)
so the nut where the hard line connects to the line is stripped and stuck good anyone gat a fix for that?
Old Sep 5, 2007 | 08:53 AM
billyinse's Avatar
Default Re: (billyinse)
ttt
Old Sep 5, 2007 | 09:05 AM
axlline's Avatar
Vise grips to get the stripped fitting loose, and replace the hardline fitting.
Old Sep 5, 2007 | 02:40 PM
yesss vise grips. i've done it twice. next time use an actual flare nut wrench and not just a box end.
Coopa B18c5
Jul 20, 2013 03:19 PM
xwhitchx
Apr 14, 2009 08:06 PM
hondazccivic
Aug 21, 2008 11:41 AM
Easy Eddy
Aug 18, 2006 01:16 PM
