fast question: stock 05' rsx-s whp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951dc5 »</TD></TR><TR><TD CLASS="quote">can seems to find anyone mention whats the stock whp for the type-s before dyno.</TD></TR></TABLE>
how can you find out the whp before a dyno??
that's a very hard question.. if you are looking for what it's rated at we can gladley tell you but trying to find the accurate number of what an 05-06 type s makes is very hard to say. Can give you a general idea but can't give you an exact number because every motor is different. You also have to take in effect of different factors like where you are, what the altitude is, how cold it is, how cold your motor is etc.... Trying to find the exact number is very very hard and in order to find <U>YOUR</U> exact number of <U>YOUR</U> car you have to go get it dyno'd.
just stock from factory and getting it dyno at a cool wheather. what would likely to bring the average number? that's all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">So you're asking what a stock 05 RSX-S puts down on a dyno?</TD></TR></TABLE>
yes..
yes..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovin’my type-s »</TD></TR><TR><TD CLASS="quote">its rated @ 187hp</TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">that's what his title says...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">can seems to find anyone mention whats the stock whp for the type-s before dyno. want to know what stock is. thanks
umm...
umm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951dc5 »</TD></TR><TR><TD CLASS="quote">fast question: stock 05' rsx-s whp?</TD></TR></TABLE>
You can't go off of that as this is not your car. This is someone elses rating. It varies 180-195.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VBPType-S »</TD></TR><TR><TD CLASS="quote">195whp stock? uhh.. id say anywhere between 175 and 185. Im at 202whp with nothin but cai and rh. so im guessing without those im around 180.</TD></TR></TABLE>
i have seen a stock type s put 191 to the wheels. It all varies that's why i say 175-195
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aco512 »</TD></TR><TR><TD CLASS="quote">there are too many possibilities that can effect the outcome of a dyno
even different dynos yield different numbers</TD></TR></TABLE>
thank you.
thank you.
i guess i might be around there since i only have i/rh. i'm waiting on some exhaust so i can run on the dyno. hope to see good numbers.
i guess i might be around there since i only have i/rh. i'm waiting on some exhaust so i can run on the dyno. hope to see good numbers. </TD></TR></TABLE>i recommend getting k-pro over exhaust
i know it cost double or more but its well money spent
i've gained about 30whp in midrange after a tune with the addition of early engagement and a 8600 redline
the exhaust will net you what? 5whp
the exhaust will net you what? 5whp</TD></TR></TABLE>
if you're lucky.
if you're lucky.
