Camber and LS/Vtec questions..
Old Sep 1, 2007 | 12:32 PM
90teggyls5's Avatar
Default Camber and LS/Vtec questions..
Ok I have a 90 Integra I just bought a few weeks ago. We noticed that the wheels and tires were leaning in so we bought a kit for the back wheels but I was wondering whats the best way to do the front? The new control arms with adjustable ball joints? Is there a little cheaper way that is just as good? Also, I'm looking to do an LS/Vtec probably using a GSR head. What all would I need in order to do that and have everything work? Any help would be appreciated. Thanks.
Old Sep 1, 2007 | 12:47 PM
littlejj26's Avatar
Default Re: Camber and LS/Vtec questions.. (90teggyls5)
well for your camber question, if you wanna fix the camber completely in the front, the best way is just to order a front camber kit and get an alignment done. i dont know if there is actually a "cheap" way to go about it, but its a lot cheaper than having to buy new tires every 3-5 months lol.
As far as your ls/vtec conversion, you would need the b16 or gsr head of course, a b16/gsr/type r oil pump, gsr ecu, and a vtec conversion kit (i believe golden eagle makes one). someone correct me if im wrong or missing something
Old Sep 1, 2007 | 01:15 PM
doood's Avatar
been there done that
https://honda-tech.com/zerothread?id=1676914
Old Sep 1, 2007 | 02:06 PM
90teggyls5's Avatar
Default Re: Camber and LS/Vtec questions.. (littlejj26)
Any recommendations for the camber kits? Im on a budget so the least expensive/decent quality route is for me. Brands? Suppliers? Thanks.
Old Sep 1, 2007 | 02:28 PM
SleeperGSR's Avatar
LS vtec makes for a large budget. I can't belive that a camber kit would thorow off you whole budget. I have a skunk 2 kit and it is great.
Old Sep 1, 2007 | 02:33 PM
GSR in progress 96's Avatar
* B A N N E D *
if you can't afford a camber kit then right now might not be the best time to do LS/vtec
Old Sep 2, 2007 | 10:59 AM
90teggyls5's Avatar
Default Re: Camber and LS/Vtec questions.. (GSR in progress 96)
Im not planning on doing the ls/vtec right now. Im not employed right now, I was just trying to figure out everything I would need and price it out so I know how much to put to the side. And for the camber kit, I have money for it. Just some of the kits seem a little pricey. Thats why I was asking who has what or for suggestions.
Old Sep 2, 2007 | 08:04 PM
b18c1ej8's Avatar
well if u still wanna do the ls vtec this thread has it all https://honda-tech.com/zerothread?id=1676914
Old Sep 2, 2007 | 08:20 PM
dmpd_ef's Avatar
i had a slammed da when i was in high school, it camberd so bad i had to buy tires like every 2 months or less. i bought a cheap camber kit from ebay for like $70, i took it to get alignd and bought brand new tires that lasted the car well over a year.
Old Sep 2, 2007 | 08:27 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlejj26 &raquo;</TD></TR><TR><TD CLASS="quote">well for your camber question, if you wanna fix the camber completely in the front, the best way is just to order a front camber kit and get an alignment done. i dont know if there is actually a "cheap" way to go about it, but its a lot cheaper than having to buy new tires every 3-5 months lol.
camber does not excessively wear tires. it's a common misconception. the wear actually comes from toe caused by lowering the car. Toe is bad by itself...add toe to camber and it's a monster that eats tires. If you just fix the toe by getting a standard alignment, your tires will wear nice and even..unless you're doing burn outs....or you have like 8 degrees of camber. I've had a few cars with around 2-3 degrees of camber. No uneven tire wear. However, My S2000 has -2.6 front and -3 rear. It DOES eat tires...but S2000s do that stock. BECAUSE OF THE AGRESSIVE TOE SETTING. But you wouldnt want to take the toe back out of an S2000 unless you like being in ditches.
ANYWAY....OP, if you plan on launching the car, a camber kit would be a good idea since it puts more rubber on the road for straight line extravaganzas. The front adjustable UCAs aren't too expensive...around $200 ish? that's not too bad. Just buy a quality kit. I've really like SKUNK2 quality. They make some well engineered ish.
sublimeh215
Suspension & Brakes
Feb 10, 2009 07:34 PM
shackler
Dec 31, 2006 09:46 AM
bigheadedhatch91
Mar 2, 2005 03:48 PM
crazyteg
Feb 11, 2002 12:41 PM
