cant fig this out
i really need some help with this, there is a noise comin from the back right side that sounds like metal rubbing against metal its not the brakes cause when i first heard it i changed the pads the next day so i would like to know if any one else has had this prob or what it could be
Most likely it's your wheel bearing. U can probably hear it most at low speeds and turning. There's a honda bulletin on it.
I just had to do my a couple weeks ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S CARTER »</TD></TR><TR><TD CLASS="quote">Most likely it's your wheel bearing.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badf20 »</TD></TR><TR><TD CLASS="quote">i really need some help with this, there is a noise comin from the back right side that sounds like metal rubbing against metal its not the brakes cause when i first heard it i changed the pads the next day so i would like to know if any one else has had this prob or what it could be</TD></TR></TABLE>
does it only happen at certain speeds? i.e only gets loud after 20mph? Wheel bearing.
other than that, make sure your lug nuts are tight. I wouldnt be suprised if your wheel is trying to divorce itself from your car.
if you feel the need to confirm wheel bearing noise you can. jack up the rear of the car. support it on jack stands. either go to sears and buy a mechanic stethoscope or use long screw drivers as a stethoscope. have buddy spin your rear wheels to the speed of the noise. using stethoscope compare any internal bearing noises from right to left. if one seems to be louder thats the bearing that bad. (note touch stethoscope to non moving components.) (also the closer you get stethoscope to component causing noise the louder it will get. so check everything for noises including rear end and axles)
good luck man
good luck man
