Innovate LM-1 readings differ from s300 (Smanager) readings *HELP*
Old Sep 1, 2007 | 09:25 AM
IntegraG2's Avatar
Default Innovate LM-1 readings differ from s300 (Smanager) readings *HELP*
I recently purchased the innovate lm-1 unit and installed it and calibrated it the way it said in the book. Now my problem is that the readings on the lm-1 unit seem to be way off with the readings on my engine management program while datalogging. I am using the analog 2 output and it is hooked up to my 02 sensor wire and also have the ground on the headphone jack hooked up to a dedicated ground point. I have programmed the lm-1 to be at 1V=10.00afr and 2V=20.00afr and changed the settings on the s300 to correspond to these numbers. I can tweak the voltage offset to be dead on at idle but it changes and is off when i drive the car. This is in a honda civic. If anyone has any experience with installing and getting it to work on a 92 civic please help me out.
Thanks for looking.
Old Sep 1, 2007 | 11:16 AM
AcuraIntegraLS-T's Avatar
Default Re: Innovate LM-1 readings differ from s300 (Smanager) readings *HELP* (IntegraG2)
Ive had the same problems with the lm-1 and lc-1 Im in for any help on this too.
Old Oct 27, 2007 | 11:15 AM
laziebun's Avatar
Default Re: Innovate LM-1 readings differ from s300 (AcuraIntegraLS-T)
http://www.hondata.net/forum/v...rt=15
try that
cslegacy
Jan 1, 2007 12:58 AM
HXvtec
Feb 22, 2004 03:12 PM
