Using Switches instead of Key and Ignition Switch?
Old Sep 1, 2007 | 09:10 AM
6genocide6's Avatar
Default Using Switches instead of Key and Ignition Switch?
I want to Convert my car over to using switches as the ignition, and eventually want to get rid of the key all together.
Does anyone know how to wire the ignition switch to use switches instead of the actual tumbler switch?
Old Sep 2, 2007 | 11:16 AM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (6genocide6)
anybody?
Old Sep 2, 2007 | 11:18 AM
6genocide6's Avatar
Oh yeah,, it's a 1990 integra
Old Sep 4, 2007 | 04:35 AM
EnjoyTheRideDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6genocide6 &raquo;</TD></TR><TR><TD CLASS="quote">I want to Convert my car over to using switches as the ignition, and eventually want to get rid of the key all together.
Does anyone know how to wire the ignition switch to use switches instead of the actual tumbler switch? </TD></TR></TABLE>
You need to locate:
Ignition Wire
Starter Wire
12V Constant Power
Accessory Wire
Hint: All of these can be found on the ignition key switch.
Then get yourself 40A or 50A toggle switches.
Take the wires from the key switch, wire them to the toggles, and bam! done.
If you cant wire a toggle switch, or locate these wires, you shouldn't be doing this task for the sake of you and your car.
Old Sep 18, 2007 | 12:11 AM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (EnjoyTheRideDC2)
well i do know how to wire, i have done a ton of wiring. i am just not sure of how to re-wire and ignition switch, a diagram/schematic would really help if anyone has one.
Old Sep 18, 2007 | 03:55 AM
Sliced Beard's Avatar
I have a simple question for you.....and it is sincere
Do you want your car to get stolen?
Old Sep 18, 2007 | 04:30 AM
jameelrose's Avatar
use a push button for the starter not a switch... why would you do this... easy acess to theives.
Old Sep 18, 2007 | 08:27 AM
King V's Avatar
Default Re: (jameelrose)
If thieves want a car, they'll take it, switch or not, doors locked or not. I do think it adds a bit of easiness to the whole stealing part, though. Hide a contact switch under the carpet somewhere that you have to step on to get the signal to go to the starter.
Old Sep 18, 2007 | 10:52 PM
6genocide6's Avatar
Default Re: (200kCivicSI)
that is my plan, all though the car is in my shop/garage locked away. but i am looking for a diagram...
Old Sep 19, 2007 | 07:58 AM
standbackimapro's Avatar
Go to an auto parts store, or a local big shop like a firestone or good year..
Ask them if they can look up the ignition wirining diagram for your car and print it out..
They usually do it for free...
Or u can just buy a manual
Old Sep 19, 2007 | 06:52 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200kCivicSI &raquo;</TD></TR><TR><TD CLASS="quote">If thieves want a car, they'll take it, switch or not, doors locked or not. I do think it adds a bit of easiness to the whole stealing part, though. Hide a contact switch under the carpet somewhere that you have to step on to get the signal to go to the starter. </TD></TR></TABLE>
not when you have airbag and you slam that bitch to the ground then what
Old Sep 19, 2007 | 07:51 PM
NJIN BUILDR's Avatar
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
not when you have airbag and you slam that bitch to the ground then what </TD></TR></TABLE>
Did 1990 integras have airbags?
Old Sep 20, 2007 | 04:42 AM
tony413's Avatar
Default Re: (NJIN BUILDR)
idk im talking about aftermarket suspension not the airbags that leave you with black/blue eyes on impact
Old Sep 20, 2007 | 09:31 AM
King V's Avatar
Under the carpet inside the car, not under the car.
Old Sep 20, 2007 | 10:31 AM
Drugs Are Bad's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (DirtySol)
You do realize it's possible that this person's intentions could be theft to begin with. After all, he's asking how to start a car without the key. Not passing judgement in any way or making accusations, just pointing out the facts.
Old Sep 28, 2007 | 07:47 PM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (Insert Marijuana Here)
Insert Marijuana Here, thank you for putting this thread back on track. does anyone have a wiring diagram for this? or has anyone done it? this is a race car, not a street car. it is parked in a locked garage.
Old Sep 29, 2007 | 07:58 PM
QuickFastGsr's Avatar
sonsacuraparts.com, I was just asking for diagrams and I was told of this site. pufff puff pass it along.
Old Sep 29, 2007 | 09:51 PM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (QuickFastGsr)
good site. but not what i am looking for.
Old Sep 30, 2007 | 01:54 PM
usdm_dc2's Avatar
nobody is gonna steal a da......
Old Sep 30, 2007 | 05:21 PM
91DA9's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (usdm_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">nobody is gonna steal a da......</TD></TR></TABLE>
I hope that comment was made in jest, but if you really believe that, then wow.
OP: I have PMed you with some help. I would not attempt this without the Helm's manual, as the rest are pretty much worthless unless you need to change your alternator, or other mundane task.
Old Oct 4, 2007 | 08:06 PM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (91DA9)
PM'ed
Old Oct 4, 2007 | 10:03 PM
slammed_93_hatch's Avatar
http://www.stockcarproducts.com/gauge5.htm
i could get all the wire colors for you if you want. I have the above switch panel on my race car.
If you don't like the the panel the switches do come out and you can put them in whatever you want. Mine is in that switch panel for now, but will be in a CF switch panel
Old Oct 4, 2007 | 11:58 PM
nblanton's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (slammed_93_hatch)
You are also going to have to disable the steering lock. That will be a lot harder than rewiring the switch. Just a toggle to the ACC and ON wires, and a safety toggle for the starter.
Old Oct 5, 2007 | 03:01 AM
rug's Avatar
rug
Default Re: Using Switches instead of Key and Ignition Switch? (nblanton)
What will your insurance company say when you disable some of the security features of your car and make it easier to steal?
/Carl
Old Oct 5, 2007 | 10:39 AM
6genocide6's Avatar
Default Re: Using Switches instead of Key and Ignition Switch? (rug)
what the hell does it matter. did you read the other posts? this is a race car. not a street car. and i am asking for help not opinions.
