Quick Question before i head out!!
Old Sep 1, 2007 | 08:05 AM
underdog_racer's Avatar
Default Quick Question before i head out!!
will a d16y head fit on a d15b7 block no problem? and does the dizzy for the d15, which is a TD41u work on the d16y head? meaning im just changin the head and using all my old stuff.. dizzy, intake, exhaust.
Old Sep 1, 2007 | 08:10 AM
Default Re: Quick Question before i head out!! (enzopastor)
oh, the head that will be going on is not a vtec also..
Old Sep 1, 2007 | 08:16 AM
Jakester9500's Avatar
negative. the dizzy will have to be per the head if you want it to fit the bolt pattern on the head. you could make the d15 work on the d16 head, but it's pretty ghetto. I did that temporarily because I was in a bind, but just get the d16y(7 im assuming) dizzy and either splice the plug or get the conversion harness for it.
Old Sep 1, 2007 | 08:19 AM
Default Re: Quick Question before i head out!! (Jakester9500)
so the dizzy angle is different?
Old Sep 1, 2007 | 08:24 AM
yea, if you put a d16y8 distributor on a d16z6, i think you might be able to get one or two bolts in. I can't entirely remember. But to create the best seal you really should have all three bolts secured. It doesn't cost too much to get the plug to make it work.
Old Sep 1, 2007 | 08:30 AM
banginek96's Avatar
the head will fit but the dizzy will not. u will need to use the d16 dizzy
Purfect
Jun 18, 2013 11:52 PM
VtecFreePrelude
Dec 5, 2009 02:41 PM
91' lude
Apr 16, 2009 11:30 AM
-[95cxhatch]-
Jul 20, 2006 05:07 AM
swindler86
Nov 3, 2005 07:24 PM
