TL seats fit in an accord?
Not sure about the TL, but know for certain the CL front seats will fit with only one minor modification, you need to drill out the rear inner mounting hole, it'll be off by about 1 inch.....all other mounting holes line up a-ok.....other than that, the wiring harness is completely different so make sure you get the harness from inside the donor CL also, makes the swap that much easier. I know because I just swapped my 99 Accord sedan front seats for 2001 CL fronts. Now I just need to figure out the rear seats, for that I'm thinking the TL will fit more directly because it's a sedan like the Accord, 4 doors.
manuelesr
Jul 7, 2007 09:43 AM
