is this an complete super charger kit (i need to no before i start my project)
I don't see the belt drive bracket assembly in the pictures.
I also don't see the FPR.
Spraying CO2 into your interfooler will make you a sad panda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnightrider »</TD></TR><TR><TD CLASS="quote">
i am also adding a cold air intake (intercooler type) with the co2 cooling systems</TD></TR></TABLE>
You fail.
You fail.
yeah spray some CO2 into your intake and tell us how that works out for you. hahaha
heres a hint: CO2 is not flammable, infact its used for putting out fires.
Although a CO2 sprayer on a real intercooler might actually do that setup some good on short runs. I hadn't really thought about that for cooling a JRSC, but it might work pretty well. The cold air would keep the rotors from getting too hot and expanding at higher boost levels, plus it would absorb heat from the whole assembly. I'd get the CO2 setup with the ring with a bunch of jets though, you'd want to spread that stuff around the intercooler. I'd also use stainless charge pipe to minimize the heat transfer before it gets to the blower.
thats what im doing the co2 spray for so this way the sc will work better nd the engine it self......anywayz the c02 set up will be very cheap 276.46 whole set up with 10lb bottle SHIPPED!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">lol @ C02 fogger in the interfooler</TD></TR></TABLE>
BoostedJeff
Aug 14, 2008 06:47 AM
