knock off BOV's ye or ne?
i'm probably going to use a greddy rs but if worse comes to worse and i have to cheap out somewhere is this a ok place to do it with a greddy replica or something?
DSM's are good and the ebay knock offs work great i have used and installed almost all the ones they offer.I run the knock off 50mm's on any of my own turbo setups and they work great
my friends difram (SP) on his knock off greaddy bov ripped so at peak boost it would open but other then that one there good as far as i know.
how much are you guys payin for the greddy knockoffs? i see some for 25 bucks and then i see them all the way up to 100 bucks... and they all look exactly the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I have a greddy knockoff and it works fine and sounds just like a real greddy. I had to cut the spring to make it work, but it works perfectly now.</TD></TR></TABLE>
Thats almost sig worthy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman »</TD></TR><TR><TD CLASS="quote">
Thats almost sig worthy</TD></TR></TABLE>bah, you have to cut the springs on all of the knockoffs or remove the second spring if it has two. Doesn't change the fact that they work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">i'm probably going to use a greddy rs but if worse comes to worse and i have to cheap out somewhere is this a ok place to do it with a greddy replica or something?</TD></TR></TABLE>
dumb question but, what is a dsm
On my Rs knock off I was still geting some surge after adjusting it so I took out the smaller spring and it worked fine.Your hit or miss on them working out of the box fine without removing or changing the spring but either way it works.Got mine for 35 or something like that from donald on hmt when they were a lower price.
Im currently using a OBX 50mm blow off on my latest turbo setup and its actually a pretty nice quality piece and works perfect.Comes with a couple weld on flanges for steel and alum. etc.It is not nearly as cheap as alot of knock offs but still considerably less then Tial.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dxhmt »</TD></TR><TR><TD CLASS="quote">Im currently using a OBX 50mm blow off on my latest turbo setup and its actually a pretty nice quality piece and works perfect.Comes with a couple weld on flanges for steel and alum. etc.It is not nearly as cheap as alot of knock offs but still considerably less then Tial.</TD></TR></TABLE>
how much did you pay for it
I think it was $125ish.Like i said it was well packaged,included all hardware,extra flages&o rings etc.Overall it seams to be a fairly nice piece not as good as a real Tial im sure but respectable.
Interesting,
So instead of buying a particular part from the original manufacturer who spent time and money on research and development to bring the product to market. you would rather purchase a product from a company that copied the original by passed all the R&D and sold it for less and used lower quality materials and also in many cases doesnt even work correctly unless modified.
Interesting mentality.
This explains why they have the damaged merchandise section in the super market. i always wondered who bought that stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman »</TD></TR><TR><TD CLASS="quote"> Interesting,
This explains why they have the damaged merchandise section in the super market. i always wondered who bought that stuff.</TD></TR></TABLE>all I heard was blah blah blah
some people cant afford $200+ BOVs and wastegates when there whole setup is only worth 500 to begin with. a kid in highschool might not be able to afford the real thing and doesnt have too high of goals so cheap knockoffs are good in that case.
bottom line is these companies arent losing any business because the people who are buying the knockoffs wouldnt have bought the name brand part in the first place because they couldnt afford it.
