another ls-v build...what u think?
Old Aug 31, 2007 | 07:37 PM
SuperiorSC's Avatar
Default another ls-v build...what u think?
heres another lsv build . this is my first motor build.l et me know what you think and how much power it should make. here is my set up
B18a1 81.5mm bore block:
Cunningham ultra light rods
SRP 12.5:1 pistons
ls knife edged and polished crank
benson sleeved
PR3 head
crower valvetrain
itr intake manifold
ctr cams
270cc rc injectors
megan 4-1 header
nx wet kit- 75shot
let me know if you think i should change anything up on my set up. thanks
Modified by SuperiorSC at 11:21 AM 9/3/2007
Modified by SuperiorSC at 11:31 AM 9/7/2007
Old Aug 31, 2007 | 07:56 PM
gibsanez's Avatar
Default Re: another ls-v build...what u think? (SuperiorSC)
There is no such thing as a generic "stage 2" cam.
You can find a better header than that.
There is no way of predicting accurate horsepower numbers, plus those threads aren't allowed.
Old Aug 31, 2007 | 10:00 PM
Mike@K-Tuned's Avatar
If your going to sleeve the block and get new forged pistons why not do 2.0L set-up for even more power
Old Sep 1, 2007 | 10:22 AM
SuperiorSC's Avatar
Default Re: another ls-v build...what u think? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">There is no such thing as a generic "stage 2" cam.
There is no way of predicting accurate horsepower numbers, plus those threads aren't allowed.</TD></TR></TABLE>
actually my machine shop is doing a stage 2 regrind so its basically you could call it a "Generic" stage 2
im not trying to spend too much money on this thing. its just for a weekend of fun @ pomona. thanks for the imput.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtecMike &raquo;</TD></TR><TR><TD CLASS="quote">If your going to sleeve the block and get new forged pistons why not do 2.0L set-up for even more power</TD></TR></TABLE>
i bought the block from a buddy of mine so it was already built
Old Sep 1, 2007 | 10:36 AM
HAMOTORSPORTS's Avatar
heres another lsv build . this is my first motor build.l et me know what you think and how much power it should make. here is my set up[/QUOTE]
i bought the block from a buddy of mine so it was already built[/QUOTE]
SOO... you are - RE- building a motor that is already built??
what cams is your machine shop going to copy??
Who in their right mind sleeves a n/a motor and leaves the bore at 81.5mm?
I'd tear the engine down and check EVERYTHING
Old Sep 1, 2007 | 04:24 PM
SuperiorSC's Avatar
Default Re: another ls-v build...what u think? (HAMOTORSPORTSUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">
I'd tear the engine down and check EVERYTHING </TD></TR></TABLE>
wow! relax.... anyways... no the motor was built be Jensen Oda of Apexi USA a few years ago for a customer and was never picked up. so i bought it off of an Apexi employee. i think its a 81.5mm bore but i cannot confirm this without calling Jensen in hawaii. and i believe they copy s2 stage2 pro series
Old Sep 1, 2007 | 04:42 PM
DonF's Avatar
235
Old Sep 1, 2007 | 08:24 PM
Default Re: another ls-v build...what u think? (DonF)
234.5
Old Sep 3, 2007 | 10:20 AM
SuperiorSC's Avatar
some changes to my setup..... check them out
Old Sep 3, 2007 | 10:56 AM
cartune network's Avatar
ur gonna need larger injectors. 270cc isnt gonna cut it. i would go with maybe 440cc just to be safe. besides your better off getting larger injectors than u think ur gonna need so that ur not maxing them out.
Old Sep 3, 2007 | 05:15 PM
gibsanez's Avatar
Default Re: another ls-v build...what u think? (cartune network)
What the hell are skunk 3's?
If you're thinking about running Skunk Pro 3's in this setup your nuts. Is this a DD?
Old Sep 3, 2007 | 07:08 PM
i think hes talking about the tuner series. well atleast i hope he is.
Old Sep 4, 2007 | 07:16 AM
SuperiorSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">What the hell are skunk 3's?
If you're thinking about running Skunk Pro 3's in this setup your nuts. Is this a DD?</TD></TR></TABLE>
yea pro 3's i have them lying around and i just thought id throw them in..... its those or ctr's..... no its for a weekend only. im doing this all on a budget and what i have laying around the house. we'll see how it turns out.
Old Sep 4, 2007 | 07:28 AM
you don't have enough compression or displacement or head flow for pro 3's.
Old Sep 4, 2007 | 11:58 AM
SuperiorSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">you don't have enough compression or displacement or head flow for pro 3's.</TD></TR></TABLE>
ok... thanks good to know....
killerpenguin21
36
Aug 2, 2009 09:55 PM
lil98civi
Apr 15, 2008 08:06 AM
Nasty3g
Apr 8, 2008 06:05 PM
lilmex
Mar 27, 2006 05:14 AM
mugenboi
Sep 18, 2005 08:32 PM
