D Series Manual Transmission Oil Change
Hello people, Im really new into this.. I was trying to change the oil of my D15B transmission but I cannot find the Speed Sensor Hole to fill again the transmission...
Can someone please show me where da hell is it located at???
If can post a pic better..
Thanks in advance..
Thanks in advance..
Its on top the tranny towards the back left...cant miss it.
get a piece of rubber tube and attach it to the end of transmission fluid and squeeze.lol
you arent supposed to fill it from there. the pic with the 2 bolts on the side is the one you want (black and white) you drain with the bottom one, and fill with the top one, replace both washers when you do this.
the reason you use this one and not the speed sensor hole is that the one on the side is there for a reason, so you do not over fill. you fill the tranny on a level plane until it starts dripping out the side. thats as full as you want it. get a funnel with a tube from auto zone or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milkmanLCA »</TD></TR><TR><TD CLASS="quote">you arent supposed to fill it from there. the pic with the 2 bolts on the side is the one you want (black and white) you drain with the bottom one, and fill with the top one, replace both washers when you do this.
the reason you use this one and not the speed sensor hole is that the one on the side is there for a reason, so you do not over fill. you fill the tranny on a level plane until it starts dripping out the side. thats as full as you want it. get a funnel with a tube from auto zone or something. </TD></TR></TABLE>
thats what i do too
thats what i do too
Yeah, that's the half-assed way of doing it - but works.
The real way is to use that *****-pumper looking thing
I just use the fill hole, 2 feet of heater hose, and a funnel.
Works great. No ***** pump or filling through the VSS required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">I just use the fill hole, 2 feet of heater hose, and a funnel.
Works great. No ***** pump or filling through the VSS required.</TD></TR></TABLE>
Yeah, but you gotta use the ***** pump on other cars where you can't just pop off the VSS and fill it through there - it's just a habit that sticks.
Or you can use the VSS because it's about 10x easier. Nobody says you can't unbolt the fill plug and fill through the VSS until liquid comes out. If you actually use the fill hole to put fluid in, you have to take it out periodically to see if its full, which makes a massive mess and adds the frustration of putting a long tube in that annoying-to-reach location multiple times.
Use the VSS while the fill plug is unbolted. /thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">they make funnels with tubes</TD></TR></TABLE>
That's all I ever use, works great every time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Use the VSS while the fill plug is unbolted. /thread.</TD></TR></TABLE>
how does it make a mess. your supposed to fill it up to that bolt so if its full it should not come out at all.
AdRoz
Transmission & Drivetrain
Jun 14, 2010 10:36 AM
SRd240sx
Feb 6, 2006 03:26 PM
4NOWJUSTADX
Nov 27, 2005 05:08 PM
ubreak_ubuy
Jul 16, 2004 02:03 PM
z6
May 11, 2004 02:22 PM
