cam gears ?
Old Aug 31, 2007 | 05:29 PM
honda_ef9's Avatar
Default cam gears ?
Ok im in process of building my b20v rs machine 12-1 cr cast 84.5s probe i beams balanced rotating assembly for the bottom end. Top end consists of fresh 3 angle vj gsr head resurfaced crower cromo retainers and blox dual valve springs an s2s1s. My question is, will i neccasarly need cam gears when tuning? I just want to make sure before i go ahead and buy a set. THANKS HT!!!
Old Aug 31, 2007 | 05:38 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: cam gears ? (honda_ef9)
yes....if you want to tune your car properly and extract every last possible hp from your setup.
Old Aug 31, 2007 | 05:42 PM
Lubo_25's Avatar
youre only going with stage 1's but you are running 12:1 in my opinion just get a nice set of skunk gears to match your cams just in case of future cam replacement...stage 1's wont keep you happy for long lol...
Old Aug 31, 2007 | 06:00 PM
Italix's Avatar
Default Re: cam gears ? (Lubo_25)
I think he might be talking about pro 1s. Otherwise there's no point of running that high of compression only for stage 1s
Old Aug 31, 2007 | 06:41 PM
doood's Avatar
been there done that
they come in handy when you need to degree in big cams
Old Aug 31, 2007 | 10:30 PM
Mike@K-Tuned's Avatar
Default Re: cam gears ? (Italix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Italix &raquo;</TD></TR><TR><TD CLASS="quote">I think he might be talking about pro 1s. Otherwise there's no point of running that high of compression only for stage 1s</TD></TR></TABLE>
Really? I run around 12.5 compression with Stage 1's.
Old Sep 1, 2007 | 12:16 PM
Italix's Avatar
Default Re: cam gears ? (LSvtecMike)
Nothing wrong with that. But if you got tuned with some pro 2s, then you know what will happen to those hp numbers
Old Sep 1, 2007 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Italix &raquo;</TD></TR><TR><TD CLASS="quote">Nothing wrong with that. But if you got tuned with some pro 2s, then you know what will happen to those hp numbers </TD></TR></TABLE>
My 1.8L engine didn't like the bigger S2S2 cams that I originally had in it. It responded much better to the smaller cams I'm using now. 2.0L engines are a much different story though.
Old Sep 1, 2007 | 03:00 PM
honda_ef9's Avatar
stage ones is what im talking about not pro ones i dont have 700 to put out on cams, ive seen basically same build as mine on itr/ctr cams making very nice number so i think s1's should be just fine till i can get better set of cams
rdwaldo
Jan 30, 2007 07:24 PM
gilou bilou
Apr 5, 2006 10:17 PM
InvaderTrax
Jan 4, 2006 04:49 AM
polishprinze
Jan 31, 2005 02:51 PM
vteec
Jun 23, 2004 12:30 AM
