Newbie to the area.... need some help CBR wont stay running.
Old Aug 31, 2007 | 03:42 PM
jdm_Integra0369's Avatar
Default Newbie to the area.... need some help CBR wont stay running.
Alright, here is the low down... I just recently purchased a 99 cbr600 and the owner before me told me that it hasn't been ran or turned over in 9 months. I obviously charged the battery and got fresh gas and then proceeded to turn on the bike. It stays on for a minute or two before idleing to a stop. If I try to give a little gas, it will hesitate for a sec, then go.... and then die shortly after. I took off the gas tank and everything seems to be in order, including the carbs, air filter and everything else. The only problem, or I think might be a problem, is when I turn the throttle the flaps inside the carbs don't move.
Like I said, I am new to this field so take it easy... I am on here to learn, not to get flamed. If you have nothing of use, don't post. Thanks in advance to everyone or anyone that can help me out.
Tim
Old Aug 31, 2007 | 05:14 PM
marmaladedad's Avatar
9 months? The gas probably went bad and gummed up the lines/jets/carbs. The battery is probably also shot as well.
Congrats on the purchase. First bike?
Old Aug 31, 2007 | 05:23 PM
.RJ's Avatar
.RJ
Default Re: Newbie to the area.... need some help CBR wont stay running. (jdm_Integra0369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_Integra0369 &raquo;</TD></TR><TR><TD CLASS="quote">when I turn the throttle the flaps inside the carbs don't move</TD></TR></TABLE>
Thats because they're vacuum operated. CV carbs... you'll need to take the float bowls off the carbs, clean them (soak for an hour in simple green/warm water mix) and probably replace the idle/pilot jets. Gas doesnt like to sit for so long.
Old Aug 31, 2007 | 05:32 PM
Default Re: Newbie to the area.... need some help CBR wont stay running. (.RJ)
I appreciate the help guys, I will probably do that tomorrow. Keep you posted
Old Sep 2, 2007 | 08:11 AM
fatboy01's Avatar
Another thing to check, after the carb clean, is the fuel pump. I had a similar problem, even after cleaning the carbs. Turned out my fuel cut-off relay went bad over the winter, so the fuel pump wouldn't cut on and the bike would die after running for a few seconds. Doubtful thats your problem, but who knows. Good luck with the carb clean
02cbrf4i
Honda Motorcycles
24
Oct 11, 2017 06:37 AM
jhhj332007
Honda Motorcycles
18
Mar 23, 2010 05:38 AM
cyco
Honda Motorcycles
17
May 15, 2008 12:25 PM
knockout
Honda Motorcycles
Jun 1, 2006 12:27 PM
02cbrf4i
Honda Motorcycles
May 24, 2004 07:14 AM
