Oil in Your GSR
Old Aug 31, 2007 | 02:40 PM
wegotmorrison's Avatar
Default Oil in Your GSR
Hey just curious to see what everyone is running in their GSR's.... And how much oil they burn between changes... I switched to 10w-40 Royal Purple from whatever they were putting in it before I had it... I burned about 1/2 a court between changes, hittin alot of VTEC..
Old Aug 31, 2007 | 02:44 PM
Tornadom's Avatar
Default Re: Oil in Your GSR (wegotmorrison)
1994 GS-R
152,5XX miles
stock internals
Mobile One Sythetic 5w-30
3,000 mile oil changes, no noticable oil burning or leaking.
Old Aug 31, 2007 | 04:01 PM
doood's Avatar
been there done that
Default Re: Oil in Your GSR (Tornadom)
mobil1
0w40 (my brother had an extra case lying around so i figured why not )
coming up on my 3k mile interval and it's down about a half quart.
Old Aug 31, 2007 | 06:10 PM
nsxtasy's Avatar
H-T Order of Merit
'94 GS-R with 168,000 miles
full synthetic oil (Mobil 1 or Pennzoil Platinum)
5W30 viscosity (which Honda recommends as preferred at all temperatures)
burns 1 quart every 1300 miles
Old Aug 31, 2007 | 10:01 PM
GSR in progress 96's Avatar
* B A N N E D *
Mobil 1 full synthetic 5w20. It burns about half a quart between changes.
Old Aug 31, 2007 | 10:26 PM
posHonda's Avatar
144k miles with mobil1 5W-30 full synthetic. still running strong
Old Aug 31, 2007 | 11:11 PM
bg-33p's Avatar
Default Re: (iVteC_PoWeR)
1994 gsr probably 1 quart every 3k miles
Old Sep 2, 2007 | 10:57 AM
TIMMY4TOES's Avatar
it depends on how many miles on motor, what kind of driven conditions, piston ring wear, cylinder heads, gasket leaks. I've seen a gsr motor burn 1 quart every two days. your questin is too general.
Old Sep 2, 2007 | 11:14 AM
vtec8804's Avatar
* B A N N E D *
98 GSR 54k miles Mobile 1 5w-30 i burn about a quart every 1000 miles or i can notice a change after a fair amount of vtakkking
Old Sep 2, 2007 | 11:37 AM
goheel's Avatar
Default Re: (vtec8804)
damn, only 54k miles and it burns that much? my 99 gsr has 99k and it still doesn't burn oil (knock on wood)
Old Sep 2, 2007 | 11:38 AM
gsR_Ace20's Avatar
00gsR here 74kmi, mobil1 (full-syn) 5W30,
about a quart between changes... yet no noticeable smoking or smell of actual oil burning???
Old Sep 2, 2007 | 12:42 PM
88civic's Avatar
Default Re: (gsR_Ace20)
2001 gsr with 23k
royal purple 5 20
no oil burning between changes...
Old Sep 2, 2007 | 01:01 PM
Default Re: Oil in Your GSR (TIMMY4TOES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIMMY4TOES &raquo;</TD></TR><TR><TD CLASS="quote">it depends on how many miles on motor, what kind of driven conditions, piston ring wear, cylinder heads, gasket leaks. I've seen a gsr motor burn 1 quart every two days. your questin is too general.</TD></TR></TABLE>
I was just curious to what other people are using, Just a curious question, soo no my question wasnt too general...
Old Sep 2, 2007 | 02:10 PM
98GSRDC2's Avatar
i use 5w30 mobil 1 full synthetic.
every 3k
but i heard its better if you use 10w30 if your car is over 100k. Supposedly to prevent oil leaks and burns because its a thicker blend.
Any feedback if that information is correct? or should i just stick with 5w30
Old Sep 2, 2007 | 08:02 PM
b18c1ej8's Avatar
Default Re: Oil in Your GSR (98GSRDC2)
5w30 mobil one burning barely any, penzoil platnium in the saem weight isnt to bad either
Old Sep 2, 2007 | 08:47 PM
nA_Gsr303's Avatar
Default Re: Oil in Your GSR (b18c1ej8)
Castrol synthetic 10w-40 and 5w-30 dosent burn oil unless im vtec happy
Anything but pennzoil
Old Sep 3, 2007 | 04:18 PM
vtec8804's Avatar
* B A N N E D *
so does 10w 30 tend not to burn as bad bc its thicker?
Old Sep 6, 2007 | 08:06 AM
TIMMY4TOES's Avatar
if power loss doesn seem to be a problem. I always like goin w/ 20w- 50.
Old Sep 6, 2007 | 11:07 AM
sgrant222's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i use 5w30 mobil 1 full synthetic.
every 3k
Any feedback if that information is correct? or should i just stick with 5w30</TD></TR></TABLE>
Mobil 1's 5w30 has a tendency to sheer to a 20 weight after less than a thousand miles as oil analysis' have shown. I would avoid that weight if I were you.
Old Sep 6, 2007 | 07:39 PM
menyuam_tou's Avatar
94 gsr with 155xxx
mobil 1 5W30
burn about half a quart of oil everytime only
Old Sep 7, 2007 | 06:12 AM
Sm0k3y's Avatar
Default Re: (menyuam_tou)
220159k - mobile 1 fully syn 5w-30. Runs great. Also, I add the lucas in it. Runs even better. highly recommended.
Old Sep 7, 2007 | 07:04 AM
Mhollaek9's Avatar
looks like mobil 1 is the choice of Honda-Tech
Old Sep 7, 2007 | 09:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My GS-R has 256,000 miles on it.
I've been using Valvoline MaxLife 5w30 since about 115,000 miles (so nearly 150,000 miles now).
After 3K miles it's only lost about 1/2 quart, which is perfectly normal for most any car, I would think.
And yes I do take it into VTEC every now and then.
Old Sep 7, 2007 | 10:39 AM
ThirdeYe's Avatar
I know it's not a GS-R but i'll chime in anyways, Amsoil 5W30, just over 130k on the LS right now. No consumption after 4-5000 mile oil change intervals whether it's using conventional or synthetic (previously used Valvoline and Havoline before switching to Amsoil)
Old Sep 7, 2007 | 04:40 PM
Default Re: (PatrickGSR94)
Is ANYONE usin Royal Purple 10w40 like me?? SHOOT.
